Leaking carbs – Mikuni BS34 on GT750
- daventry
05 Nov 2014 03:23
I went to take the bike to get registered the other day but noticed there was a significant amount of petrol leaking from the carbs. It's a Kawasaki GT750 with Mikuni BS34s.
It gets worse when I switch to PRI. I've recently rebuilt my carbs so they're pretty clean and I have the vacuum caps on 3 carbs with the vacuum tube connected to the tank. The attachment shows exactly where the petrol is leaking from.
Any suggestions on how to fix this?
- KZJOE900
- Administrator
Super Users
Re: Leaking carbs – Mikuni BS34 on GT750
05 Nov 2014 04:39
Where is it leaking from the carbs? Fuel inlet tee? Coming out of the bores? If you can't determine where the leak is when it is mounted on the bike, take them off the bike. Mount them to a rack holder (if you have one made) and hook it up to an auxiliary tank. You can control the off/on flow by raising or lowering the auxiliary tank above or below the carbs. Have a pan below the carbs to catch leaking fuel. You should be able to see where it is leaking from. But by what you describe, your petcock is leaking; which is problem number one. Your second issue is the carbs are leaking from somewhere as well. Which would could be the fuel tee or a stuck float.
You can easily check petcock by taking the fuel line off at the tank and seeing if it is leaking. You should only see flow when you put it on PRI. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- turboking
05 Nov 2014 05:35
looks to be float/ needle related ...........if your tank has rust in it..... possible red rust/ dirt, debris in tank ?
incorrect float height/level.........bad fuel needle seat. :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
