Vm28 pump delete question
  • floivanus
  • floivanus's Avatar Topic Author
03 Nov 2014 17:47
#652811
To properly delete the accelerator pump on the 80ltd 28s you just swap out the float bowls for ones from some other non pump carbs like the extra set of 26s I have sitting around?
Past; 78 kz1000, 83 kz550
Andrew
  • loudhvx
  • loudhvx's Avatar
Re: Vm28 pump delete question
03 Nov 2014 22:24
#652828
I don't think you even have to do that much. I thought you could just block off some ports with a blanking plate... but it's been years since I've inspected some de-pumped 28's.
  • PDXDave
  • PDXDave's Avatar
04 Nov 2014 18:19
#652891
So, new guy curiosity here... Why would you delete the accelerator pump on the VM28's?
Just wondering....
I'm mid rebuild on a set right now and am looking for new needles.
  • floivanus
04 Nov 2014 19:37
#652904
It's a request from a friend; it was disconnected because "it was a hassle" the sets I have still are hooked up AND working so honestly i dont know. One of my sets of spare parts carbs has lag screws for drain plugs so it is obvious a lot of stupid crap gets done with bike carbs
Andrew
  • martin_csr
  • martin_csr's Avatar
05 Nov 2014 06:05
#652930
PDXDave wrote: So, new guy curiosity here... Why would you delete the accelerator pump on the VM28's?
Just wondering....
The carbs had to be jetted lean at the factory for EPA regs, so the accelerator pump was added to inject more fuel into the carburetors during acceleration or something like that. So if you rejet the carburetors, then apparently the AP isn't needed. This is my understanding, anyway.
