Outside rich inside lean! Help
  • jmoney05
  • jmoney05's Avatar Topic Author
02 Nov 2014 10:09
#652629
The two outer cylinders and very rich while the inner two are fine. VM26 s on a 1978 kz 650 D
What could cause this? Any input is welcome,
1978 Kz650D
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Outside rich inside lean! Help
02 Nov 2014 12:00 - 02 Nov 2014 12:48
#652635
could be a vacuum leak at the carb bodies.
could be a bad rubber intake boot. They can dry out, rot and crack letting air in creating a lean condition.
Lean is caused by two methods.
1. to much air to fuel. Proper fuel flow / to much air.
2. not enough fuel. Proper air flow / restriction of fuel / not enough fuel.
Last edit: 02 Nov 2014 12:48 by 4TheKZ1000.
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: Re:Outside rich inside lean! Help
02 Nov 2014 12:59
#652640
Does it have pods? PO may have put larger jets on outside carbs to compensate a lean condition caused by the amount of air on outside carbs.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
02 Nov 2014 18:36 - 02 Nov 2014 18:37
#652678
jmoney05 wrote: The two outer cylinders and very rich while the inner two are fine. VM26 s on a 1978 kz 650 D
If not already done, would assure correct fuel levels by performing the clear tube test.
Incorrect fuel level can result in too lean or too rich mixture in an otherwise perfect carb.
Good Fortune! :)
Last edit: 02 Nov 2014 18:37 by Patton.
The following user(s) said Thank You: jmoney05
  • jmoney05
02 Nov 2014 18:38
#652679
The bike does have pods, I'm sure there is no vac leaks. The inside plugs look decent the outside plugs are solid black.
The bike was running so rich that my oil was getting contaminated and all four plugs were solid black. So I changed the oil and put new plugs.
I had the carbs off and changed the jets ( they were all the same ) from 117.5 I jetted down to 115 and also put new needle and seats, and now is my current situation with the outside cylinders plugs reading solid black.
The bike runs a lot better since re-jetting but is still way off.
1978 Kz650D
  • jmoney05
02 Nov 2014 18:39 - 02 Nov 2014 18:40
#652680
I will check the fuel levels ASAP ,if this is my problem shud be an easy fix.
1978 Kz650D
Last edit: 02 Nov 2014 18:40 by jmoney05.
02 Nov 2014 18:46
#652683
jmoney05 wrote: ... bike was running so rich that my oil was getting contaminated ....
Often results from a leaking float valve, accompanied by an imperfectly functioning overflow circuit.
Good Fortune! :)
  • martin_csr
  • martin_csr's Avatar
03 Nov 2014 06:05
#652731
jmoney05 wrote: The bike does have pods, I'm sure there is no vac leaks. The inside plugs look decent the outside plugs are solid black.
Are they oily black or sooty black?
What ignition system is on the bike & does it have the stock coils?
I'm thinking it might be poor spark, possibly from a bad 1-4 coil.
The following user(s) said Thank You: 4TheKZ1000
03 Nov 2014 07:21 - 03 Nov 2014 07:35
#652741
Observed fat blue sparks on new correct plugs would indicate -- but not guarantee -- that the ignition system is okay. (With plugs removed and grounded against the engine head, spin over the engine to observe the spark quality on each plug.)
While there might also be an ignition issue, gasoline intrusion into the crankcase likely resulted from a carb problem.
The scenario is that raw gasoline rises up into the carb bore and is sucked into the combustion chamber, from where it then blows out the exhaust and/or washes down around the pistons and rings into the crankcase. Under such condition -- basically flooded -- , the cylinder likely fails to combust. And the spark plug gets dripping wet with raw gasoline.
Hopefully, the new float valves have remedied the issue of gasoline intrusion into the crankcase.
Good Fortune! :)
Last edit: 03 Nov 2014 07:35 by Patton.
03 Nov 2014 07:50
#652744
Sometimes the clear-tube test indicates that gasoline rises way too high inside the carb, perhaps higher than the overflow tube (likely resulting from an obstructed overflow circuit).
In any event, would also assure that the overflow circuits are clean and clear. Because a new perfectly functioning float valve may later start leaking (for whatever reason), and when that happens, the overflow circuit needs to be working.
Good Fortune! :)
  • jmoney05
06 Nov 2014 05:42
#653023
Plugs are sooty black,will check the spark as well,just no time to get in the garage till the weekend, you all are such great help with all the ideas,experience, and know how, for that I am gratefull.
1978 Kz650D
