Fuel intake modifictions
- PLUMMEN
Re: Fuel intake modifictions
30 Oct 2014 16:18
Im thinking its a 413 ramcharger,almost looks like a slant six with that other valve cover hidden! :laugh:
- PLUMMEN
30 Oct 2014 16:22Are those webbers or del ortos?(spell check :laugh: )650ed wrote:peter1958 wrote: Send it to Plummen he can get a 4 barrel on that head. omg just kidding
A pair of these would be nice.Ed
Attachment 00003a_2014-10-30.jpg not found
Looks expensive either way.
30 Oct 2014 16:34
- peter1958
- Banned
30 Oct 2014 16:46
www.kzzone.com/
- LarryC
30 Oct 2014 18:37 - 30 Oct 2014 18:46kraber wrote: yes I have already checked larys link, to bad he cant educate instead of ridicule. The weight of evidence is agains me, I dont want a rod just my last bike to lAST ME TO THE MY END. Thanks for the great input, anybody know where I can get som engine, head and cabr work
C'mon... I didn't mean to ridicule you... just having a little fun at your expense..
If you want do it... read up on the link I posted for you for a starter and if you want the pertinent air / fuel requirements I'll do that for you... seriously I will
What the hell... succeed with it and the hand out salt shakers with the crow drum sticks you'll be giving out... we'll have to eat them :laugh:
Larry C.
Last edit: 30 Oct 2014 18:46 by LarryC.
- LarryC
30 Oct 2014 18:39 - 30 Oct 2014 18:39
forgot the quote
Larry C.
Last edit: 30 Oct 2014 18:39 by LarryC.
- LarryC
30 Oct 2014 18:40650ed wrote:peter1958 wrote: Send it to Plummen he can get a 4 barrel on that head. omg just kidding
I got so accustomed to face book I was honestly looking for the LIKE button below that pic :woohoo:
Larry C.
- LarryC
30 Oct 2014 18:44 - 30 Oct 2014 19:03kraber wrote: we sync carbs because each cylinder has a different performance, even in an 8 cylinder, a single carb eliminates the need for syncing.
Yes..but because you can't synch something to another if it doesn't exist...
With a single carb setup and plenum manifold you can run into uneven fuel distribution between cylinders because of the uneven pressure differentials per port. That stated you really can't claim the single carb as beneficial from that perspective.
With one unit per intake runner you help to alleviate that situation.
If carb synch difficulties is your main issue then consider this. The last years of the bike Kaws with carbs on them used CVK Keihins. The're a breeze to synch because the use a simple phillips head screw that's spring loaded...no locknut to fuss with.
A member named Bozo...[i think] put a rack on a KZ1000 and according to him, they worked great. That might be and alternative project but with more promising end results and less modifications. You will most probably have to re rack the carbs though.... But as I recall the first 600 Ninjas had cam chains down the middle of the engine so perhaps ...might be a possible fit with less work than a motor with a cam chain on the end of the crank....
Look him up and send him a PM. He built a nice bike... He's NOT a hacker by any means...
Larry C.
Last edit: 30 Oct 2014 19:03 by LarryC.
- DSummerlin
30 Oct 2014 18:54
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's an adapter for a single carb on a KZ I found...
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
- bountyhunter
30 Oct 2014 18:55PLUMMEN wrote:Did you use top of the line performance cars and a picture of a Pontiac with 3 deuces in the same post? :S :woohoo:650ed wrote:80B4 wrote: Aircraft engines are designed to run at one constant low rpm for hours. Street motorcycles need to be able to run well from idle to redline. Your Kawasaki is also in a much higher state of tune then 99% of the aircraft engines. If you want your bike to be slower and less fun to ride a single carb is a great mod to try.
Same with cars. High performance cars that used carbs nearly always had multiple carbs. In fact, I can't recall any top of the line performance cars that used a single carb. Ed
Just one example:
Attachment 00003_2014-10-30.jpg not found
Ls-6 454 in the 70 chevelle/L-88 427s were mostly single 4 barrel motors from gm,the original Lt-1 370hp 350s were single 4 motors,thats just a couple off the top of my head anyway
Motorcycle motors and car motors are 2 totally different animals as far as design and lay out.
Using three deuces had the advantage of allowing running off just one carb for "normal" and then the other two kicked in as you get on it. Even the gigantic 1050 CFM Holley "double pumpers" which were supposedly one four barrel carburetor actually were two carburetors. The smaller primary side for normal running and the giant secondary when you wanted to spray raw gas out the tailpipe like a crop duster....
- bountyhunter
30 Oct 2014 18:58LarryC wrote:kraber wrote: I was wondering what a crb kit cost X 4.
Ps I know I am bucking the trend. Some years ago I saw a tubo-ed kz1000 and it had only one carb, I am not going to put a tubo I just like being different
No, you're not bucking a trend....you're bucking common sense and logic... IT IS just that simple. But it's your circus so you can make the animals dance anyway you please.... The mistake is in thinking the crowd will applaud when you turn a roaring lion into an armpit scratching monkey...
If you want to know how much air flow the carburetor needs to meet the piston demand..I'll be happy to give you that number. But remember this... A carburetor's primary job is to deliver the appropriate fuel curve for the entire RPM range of the engine. That's the part that's going to take some experimentation. I suggest you start with an old dirt bike carb fitted with a power jet, a slection of needles and a box of jets. If you want to know how many lbs of fuel per hour you need the carb to deliver, I'll give you that number as well... Then go have fun and holler back with the results...
Here's some reading material you may find useful in your endeavor.
www.britishracecar.com/RichardBrown-Triumph-Spitfire.htm
Bear in mind, that back in the old days, most car engines were severely under carbureted so you could bolt on more carb and get more power. Bike engines are set up pretty much on the optimum point for the cams and headers so that doesn't apply.
- LarryC
30 Oct 2014 19:00bountyhunter wrote:PLUMMEN wrote:Did you use top of the line performance cars and a picture of a Pontiac with 3 deuces in the same post? :S :woohoo:650ed wrote:80B4 wrote: Aircraft engines are designed to run at one constant low rpm for hours. Street motorcycles need to be able to run well from idle to redline. Your Kawasaki is also in a much higher state of tune then 99% of the aircraft engines. If you want your bike to be slower and less fun to ride a single carb is a great mod to try.
Just one example:
Mopar used 3 duces back in the day....they ran too. In 70 they had AAR Cuda 340 6 Packs. They build just enough to meet homologation of the Cuda and I think the Dodge Challangers for the T/A racing class.
Larry C.
