Fuel intake modifictions
  • LarryC
  • LarryC's Avatar
Re: Fuel intake modifictions
30 Oct 2014 09:56 - 30 Oct 2014 10:10
#652226
kraber wrote: I was wondering what a crb kit cost X 4.
Ps I know I am bucking the trend. Some years ago I saw a tubo-ed kz1000 and it had only one carb, I am not going to put a tubo I just like being different
No, you're not bucking a trend....you're bucking common sense and logic... IT IS just that simple. But it's your circus so you can make the animals dance anyway you please.... The mistake is in thinking the crowd will applaud when you turn a roaring lion into an armpit scratching monkey... :)
If you want to know how much air flow the carburetor needs to meet the piston demand..I'll be happy to give you that number. But remember this... A carburetor's primary job is to deliver the appropriate fuel curve for the entire RPM range of the engine. That's the part that's going to take some experimentation. I suggest you start with an old dirt bike carb fitted with a power jet, a slection of needles and a box of jets. If you want to know how many lbs of fuel per hour you need the carb to deliver, I'll give you that number as well... Then go have fun and holler back with the results... :)
Here's some reading material you may find useful in your endeavor.
www.britishracecar.com/RichardBrown-Triumph-Spitfire.htm
Larry C.
Last edit: 30 Oct 2014 10:10 by LarryC.
The following user(s) said Thank You: PLUMMEN, 80B4
30 Oct 2014 11:26 - 30 Oct 2014 11:34
#652229
PLUMMEN wrote: .....
Did you use top of the line performance cars and a picture of a Pontiac with 3 deuces in the same post? :S :woohoo:
Ls-6 454 in the 70 chevelle/L-88 427s were mostly single 4 barrel motors from gm,the original Lt-1 370hp 350s were single 4 motors,thats just a couple off the top of my head anyway
Motorcycle motors and car motors are 2 totally different animals as far as design and lay out.
That was the top of the line Pontiac at the time. It wasn't meant to be compared to other brands. However, even a single 4-barrel carb has multiple venturis whereas a typical bike carb has only 1 venturi. Perhaps I should have said "single barrel carb" instead of single carb. Try putting a single barrel carb on that 454! :laugh: :laugh: :laugh: Ed
Last edit: 30 Oct 2014 11:34 by 650ed.
30 Oct 2014 11:30
#652230
LarryC wrote: "..... But it's your circus so you can make the animals dance anyway you please.... The mistake is in thinking the crowd will applaud when you turn a roaring lion into an armpit scratching monkey... :)"
:laugh: :laugh: :laugh: Pick me up off the floor - that is FUNNY! (It also happens to be true.) Ed
  • kraber
  • kraber's Avatar Topic Author
30 Oct 2014 12:03
#652233
Thank you for that most warm retort. I must say you must know an awful lot about bikes
Do something every day and it will get done
  • PLUMMEN
  • PLUMMEN's Avatar
30 Oct 2014 12:30
#652236
Yes Larry does. ;)
  • Arial Bender
  • Arial Bender's Avatar
30 Oct 2014 12:38
#652238
Check Larry's profile, click on link.
78 Z1-R
  • kraber
30 Oct 2014 12:47
#652239
yes I have already checked larys link, to bad he cant educate instead of ridicule. The weight of evidence is agains me, I dont want a rod just my last bike to lAST ME TO THE MY END. Thanks for the great input, anybody know where I can get som engine, head and cabr work
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
30 Oct 2014 14:46
#652261
Send it to Plummen he can get a 4 barrel on that head. omg just kidding
30 Oct 2014 15:17
#652265
peter1958 wrote: Send it to Plummen he can get a 4 barrel on that head. omg just kidding
A pair of these would be nice. :) Ed
Attachment 00003a_2014-10-30.jpg not found
  • PLUMMEN
  • PLUMMEN's Avatar
30 Oct 2014 15:46
#652267
:woohoo:
  • PLUMMEN
  • PLUMMEN's Avatar
30 Oct 2014 15:52 - 30 Oct 2014 15:52
#652268
maybe some sort of variation of this?
:woohoo:
Last edit: 30 Oct 2014 15:52 by PLUMMEN.
30 Oct 2014 16:12
#652273
Wedge or hemi? Ed
