kehin CV 34s
- piecrazy4
kehin CV 34s
29 Oct 2014 11:01
OK guys my bike has some pretty messed up carbs a local shop has another 84 Zn 700 and claims mine need needles and seats at 30 a carb for parts and a diaphragm and slide they offered me the ones off the other bike for 100 dollars if I let them have mine they claim there's are perfect and don't need anything the only reason I want to trade is mine has one broken float tower is this a decent trade if I do it I want to see there's apart
1984 ZN 700 ltd current project
- piecrazy4
Re: kehin CV 34s
29 Oct 2014 11:10
Just to clarify they want my set of carbs for theres
- jayrodoh
Re: kehin CV 34s
29 Oct 2014 11:54
If you're saying they'll trade you a set of CV34's ready to go for your old set and $100 I'd say that's a great deal. You won't find someone to rebuild yours for $100 even if the tower wasn't broke. Almost sounds too good to be true. How well do you know this shop?
1982 KZ750-M1 CSR
- piecrazy4
Re: kehin CV 34s
29 Oct 2014 16:19
Don't it was my first time there when I got the bike it broke down in front of a guys house who had just redone a Honda silverwing he told me about them
- jayrodoh
Re: kehin CV 34s
29 Oct 2014 18:04
My advice would be to go look at the carbs they are offering. Check the diaphragms if you can as they're expensive. Make sure the slides move freely. If you can look in the bowls make sure the floats aren't sunk(full of gas). Take yours with you to ensure the throttle brackets etc. are the same. If that's all good I would go for it. After that its small things. Worst case you do that and get 4 carb kits from Z1 enterprises and you're still under $200. If you've shopped around, you'll notice individual 34's don't show up that often.
Keep in mind no set of carbs will be bolt on and go. Once you get them, you'll set your float levels on a bench. Mount them, adjust your idle mixture and then sync.
There are more seasoned guys on here, they may chime in as well.
1982 KZ750-M1 CSR
- piecrazy4
Re: kehin CV 34s
29 Oct 2014 18:47
Yes I already know I am going to have them disassemble them for me to check them out before I'm willing to do this
Re: kehin CV 34s
29 Oct 2014 20:07
Z1 Enterprises sells the various O-rings you will need for a rebuild. No way I'd dump a bunch of money on some inferior aftermarket carb kits when all you need is the rubber parts.
- guitargeek
Re: Re:kehin CV 34s
05 Nov 2014 13:16
I hated my CV34s, they were hard to find parts for. I'm much happier with Mikuni BS34s!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
