Running bad 4-5k
- New 750
Running bad 4-5k
28 Oct 2014 12:16
Hello all, first I would like to introduce myself, I'm Nate live in Greenbay WI, and am the proud owner of a 1977 KZ750 (my second bike) my first was a yamaha xs400 Wich I traded on Craigslist for this bike just two days ago, I really like this bike I wanted something with more power and this bike is perfect for me! The first couple days I drove all over with no issues then the left carb would leak fuel so I pulled them off (mukini bs38) I believe? And as I suspected the float seat was gummed up, cleaned both carbs and now the bike runs like crap between 4-5k. So I pulled them back off cleaned them again, moved the needle jet c clip from the very top position to the second from top position, adjusted the two little fuel mixture screws 1 turn out per the manual, then 1.5 out. Still no change? It was running like a champ before what gives? Thanks alot in advance! Ps pulled both plugs they look great, nice and tan color.
1977 kawasaki KZ750
- New 750
Re: Running bad 4-5k
30 Oct 2014 12:16
Update..... My carbs where way out of sync, plus my throttle cable was was out of adjustment causing a very high idle. Amazing what you can accomplish with the service manual :lol:
1977 kawasaki KZ750
The following user(s) said Thank You: !Seymore
