How many CC,s can 29 smooth bore handle
  • spdygon
  • spdygon's Avatar Topic Author
11 Oct 2014 08:40 - 11 Oct 2014 08:42
#650346
So I'm looking at 29 smooth bore carbs.
Would like to know if they can handle up to 1200cc on my KZ?
Or should I save the money and by 34 flats life's?
Thx
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 11 Oct 2014 08:42 by spdygon.
Re: How many CC,s can 29 smooth bore handle
11 Oct 2014 08:50
#650347
Are CC's the limiting factor or would the limiting factor be the flow rate of the cylinder head? Ed
  • TexasKZ
  • TexasKZ's Avatar
11 Oct 2014 08:58
#650348
And the cams and exhaust system. On a really mild 1200, the 29s are probably adequate, bot on a really radical 1200, the 29s would be the weak link.
  • spdygon
11 Oct 2014 17:58
#650409
yes.....light head port and street cams with a 1200cc piston kit.
thx
1974 Z1 900 project
  • PLUMMEN
  • PLUMMEN's Avatar
11 Oct 2014 21:52
#650430
Theyre plenty of carb for a street driven 1197 motor,of course if you have to go out and buy a set you might be money ahead to just buy a set of new 29-31 cr specials. ;)
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
Re: Re:How many CC,s can 29 smooth bore handle
08 Jan 2015 14:50
#658093
I'm thinking 34's would be the ticket with plenty of porting. I have a 1075 kit with .410 cams and head ported to match the j boots and 31's and while I haven't ridden it yet I have a feeling...
79 LTD B3
  • DFIGPZ
  • DFIGPZ's Avatar
10 Jan 2015 05:17
#658241
I know the 29s were a good carb but in todays world I think you are foolish for paying big money for used carbs that I would bet have issues your best bet is the 34s or even the 36s I have used both on plenty of builds W/O issue now on the other hand if you want the old school carbs then 29s or 33s are it.
1984 750 Turbo
  • spdygon
10 Jan 2015 08:18
#658264
thx guys.......
since my first post i have purchase a 79kz1000ltd . its on my sig.
1974 Z1 900 project
