can't start my KZ750 after sitting for sometime
  • karoliens
  • karoliens's Avatar Topic Author
15 Sep 2014 22:12
#647718
So I can't start or it is hard to start after my KZ750 was sitting for some time. Previously it started just fine now it just rotates the starter and sometime bangs in the end. Should I up the idle screw?
83' Kawasaki KZ750E-L2
  • bountyhunter
  • bountyhunter's Avatar
Re: can't start my KZ750 after sitting for sometime
16 Sep 2014 01:30
#647726
It might be flooding one or more carb. As you crank, the plug clears and finally pops. Same thing with bad valve seals because oil drains down and fouls the plug.... then as you crank it, the gas cleans the plug and it finally fires.
Guess how I learned about that...... :ohmy:
16 Sep 2014 04:20 - 16 Sep 2014 04:20
#647727
How long is "some time"? Hours; days; weeks; or months? Ed
Last edit: 16 Sep 2014 04:20 by 650ed.
  • karoliens
16 Sep 2014 04:44
#647731
Months. And when I said bangs I meant sound.
  • martin_csr
  • martin_csr's Avatar
16 Sep 2014 04:56
#647732
Has the weather been hot & does your fuel contain ethanol?
I would drain the carbs & maybe the fuel tank, then add fresh fuel.
Also, be sure to check the battery.
16 Sep 2014 04:57
#647733
If it sat for months the carbs are probably clogged up. Gasoline leaves a nasty residue after a while. If mine, I would start by cleaning the carbs. Ed
  • GPzEric
  • GPzEric's Avatar
16 Sep 2014 14:39
#647801
650ed wrote: If it sat for months the carbs are probably clogged up. Gasoline leaves a nasty residue after a while. If mine, I would start by cleaning the carbs. Ed
This.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
  • karoliens
23 Sep 2014 02:31
#648447
But they were fully cleaned before.
  • martin_csr
23 Sep 2014 06:26
#648462
The gasoline doesn't care. If it sits around all bored, doing nothing, it will do what it wants to do. :)
Did you try using fresh fuel & charging the battery?
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
23 Sep 2014 11:16 - 23 Sep 2014 11:17
#648519
karoliens wrote: But they were fully cleaned before.
Sorry to say that it does not take the ethanol based fuel (these days) long to clog the small pathways in the carbs. Might get some Seafoam (fuel additive), pour a few ounces in with fresh fuel and see if you can get that to flow thru the carbs. Should assist, a bit, with the clean out and keep your fuel stable if it has to sit for a while.
If this doesn't work, the only other option is to get the carbs cleaned again...
edit: Oh, and drain the old fuel. You should be able to use it in your car with no ill effects...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 23 Sep 2014 11:17 by !Seymore.
