Re-Assembling VM 26 Carbs. ???
- kzdcw
- 77' KZ1000A
10 Sep 2014 17:28
Got my rebuild kits from Z1 Ent. with new starter plunger collars and rubber dust caps. When you guys re-assemble your carbs., do you use any assembly oil or lubricant when threading the new jets or starter plungers into the casting of the carb. body? All the dis-assembled carbs. have been thoroughly cleaned but thought when installing any rubber o-rings or jets, it would make assembly easier.
77' KZ1000A
- 74ullc
Re: Re-Assembling VM 26 Carbs. ???
10 Sep 2014 20:17
I use some dow corning stuff I get from my neighbor on all o-rings and rubber sealing parts. I thought it said air gasket on the label but I can't find it online. I'll have to run by there tomorrow and see what it is again. The stuff that seems to be the closest I can find online is called Dow Corning 111, but I'm not sure if that's the same stuff, tube looks the same. I seem to remember something about it being high temp on the label also.
It's a very thick translucent white stuff and it works great. I used it on the carb bowl gaskets on my Honda VF700, they are o-ring type. Everyone says they ALWAYS leak when you first put them together until the gasket swells up. Mine never leaked when I used that stuff. Second time I didn't use it and sure enough they leaked for a few hours.
As for the jets.....when I'm cleaning carbs I put the cleaned jets in small baggies and spray wd-40 in there with them. Just to keep them from corroding before I reassemble, not to lubricate them. I spray the inside of the bowls and carb bodies also, just because its so darn humid here that stuff will corrode or rust instantly if you do nothing after using carb cleaner. I know the anti - WD-40 crowd will have their say but it works for me.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
11 Sep 2014 06:23
Dow Product 111 is a VERY thick silicone paste. I use it for certain applications like weather sealing on a convertible. Here's the description on the box and a pic of the stuff as it comes out of the tube. Ed
Attachment Dow111a.jpg not found
Attachment Dow111b.jpg not found
Attachment Dow111c.jpg not found
Attachment Dow111d.jpg not found
Attachment Dow111e.jpg not found
- kzdcw
- 77' KZ1000A
11 Sep 2014 07:45
Interesting stiff Ed, but I don't think I would use it my situation.
I'm more concerned with the fuel parts that SCREW into the carb. body like jets, float valve seat, choke plunger, etc. Do I apply a little lubricant to these parts?
Also, the paper top chamber gasket and bottom float bowl gasket that comes with this rebuild kit, do you use any sealant there?
77' KZ1000A
- Mcdroid
- Gone Kwackers
11 Sep 2014 07:49 - 11 Sep 2014 07:51
Carb gaskets go on dry and and jets and anything that screws in gets no lubricant (no dirty comments please)...any item that is in contact with fuel, re-assembles with no lubricant.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 11 Sep 2014 07:51 by Mcdroid. Reason: clarity
- kzdcw
- 77' KZ1000A
11 Sep 2014 08:16
Okay Mcdroid, Just wanted to make sure before I put everything back to ether again.
77' KZ1000A
11 Sep 2014 12:45Mcdroid wrote: Carb gaskets go on dry and and jets and anything that screws in gets no lubricant (no dirty comments please)...any item that is in contact with fuel, re-assembles with no lubricant.
+1 Ed
- 74ullc
11 Sep 2014 13:25kzdcw wrote: Got my rebuild kits from Z1 Ent. with new starter plunger collars and rubber dust caps.
I've looked on Z1E and cannot find kits that have the starter plunger collars and rubber dust caps? Do you have a link or P/N for them?
Also....the little T shaped joints where the fuel goes into the carbs started leaking on mine after I had the carbs off the bike a few times. You might consider replacing them with the aluminum ones from Z1E. I know they're kinda pricey but you wont have to worry about it again.
www.z1enterprises.com/ItemDetails.aspx?i...minum&item=ZSM46-002
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
- kzdcw
- 77' KZ1000A
11 Sep 2014 17:46
Z1 Ent. Choke Collars ZSM073-014
Choke Plunger Caps 16039-015
Hope that helps !
Hope that helps !
77' KZ1000A
- 74ullc
11 Sep 2014 19:03
Thanks, I didn't know the little plunger caps were available. I didn't really hunt them hard because mine are ok, but next time I make an order I'll order a set to squirrel away.
It is Dow Corning 111 that my neighbor gave me. He just squeezed some out into a baggie, that's why I wasn't sure what it was. I use it on pretty much every o-ring I put on anything now. Just a little, and pretty much wipe it all off. It seems to help the o-rings seat better and not get twisted or kinked.
I used it on the bowl and top cover gaskets on my VM26SS carbs also. May not need it but it's so thick it has sealing properties and also keeps the paper from sticking next time you take them apart. I reused the original gaskets. Worked for me, no leaks.....but....as they say YMMV.
If you bought carb kits, you might be better off staying with the original float needles and seats, same for the jets. I've read many many times that the OEM stuff is better than what comes in the kits.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
