poor idle / strong hesitation at WOT
  • alexnelson
  • alexnelson's Avatar Topic Author
07 Sep 2014 16:02
#646608
Mistakenly put this in the engine thread. Cross-posting.
Symptoms
Idle: Takes a good 10 minutes to warm up to the point where I don't need to use the choke - mid-summer. This has gotten progressively worse over the last two seasons.
Throttle: When I twist to WOT, power drops out/hesitates then picks up after a couple seconds. Typically in the 4K-6K RPM range.
Exhaust: Little rich. Getting small backfires after letting off the throttle at higher RPMs.
All of these symptoms have been progressively worsening over the last 2 years.
Status
I have the carb off now to check for debris. It's looking fairly clean. I also needed to check my jetting because I didn't know where I was at. Previous owner put on a 4-1 so I wanted to make sure jetting was up at least a step. It is. I believe 102.5 mains are stock. I'm at 105. Pilots are at 15, which is stock.
Last year I had a mechanic set the valve clearances. I also asked them to fix this hesitation issue I have. No luck. Asked another mechanic to take a look at it this year too. No luck. Pretty bummed about that.
Electrical is good. I have a Dyna ignition and coils. Good solid spark. I'm pretty sure fuel from the tank and through the petcock is coming in fine.
Air filter is maybe a tad dusty but not so bad. I sprayed a little carb cleaner into the air box with the filter out and it had no real effect.
Next steps
I'm cleaning the carb. I can't see any obvious reason to change the jetting. I haven't checked the floats yet so that's on my trouble shooting list.
Any ideas guys? Gone through two mechanics and I've been stumped on this for a couple years now.
Cheers,
-A
78 KZ650-D1
K&N pods + 4-1 Pipe
Mikuni VM24 - 7.5/115/#4 Clip
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
  • nickleo373
  • nickleo373's Avatar
Re: poor idle / strong hesitation at WOT
07 Sep 2014 17:32
#646623
Check for vacuum leaks around the carb holders
1981 KZ550C LTD
"If you ain't first, you're last"
