Carb fuel tubes
- koloj
Carb fuel tubes
04 Sep 2014 17:47
Its the tubes between the to carbs have middle one and two for both pairs of carbs I was wonder what orings will work for them cause I sprung a little leak one 1980 kz750 h1 four
- Zephyrrider
Re: Carb fuel tubes
11 Sep 2014 13:46
Did you mean the overflow tubes ?
Mick
1994 ZR750 Zephyr C4.
Re: Carb fuel tubes
12 Sep 2014 06:22 - 12 Sep 2014 06:23
From Kawasaki.com the o-rings are listed as Active. At Partzilla they are $1.79 each. ouch.
Kawasaki does not provide any measurements for them. Searching the part # at Z1Enterprises.com didn't yield any results, but they do carry a good selection of o-rings. A HF metric nitrile or viton o-ring kit may have the needed size --- it wouldn't have to be identical. Auto parts stores sell individual o-rings out of a similar kit.
Last edit: 12 Sep 2014 06:23 by martin_csr.
- Zephyrrider
Last edit: 12 Sep 2014 13:13 by Zephyrrider.
- Zephyrrider
- koloj
Re: Re:Carb fuel tubes
19 Sep 2014 20:25
For future knowledge advance auto mm oring kit fit them perfect thanks again
