Airbox holes ports at bottom - what are these for?
  • FaultedGeologist
  • FaultedGeologist's Avatar Topic Author
  • The truly educated never graduate...
02 Sep 2014 07:37
#645903
My airbox has holes at the bottom front that I thought were for the overflow from the carbs. I swear I have seen pics or manual information that shows this flow, though now I cannot find it. Please see pic below and let me know what this is for. The bike is a 1981 KZ750 LTD 4/H. Do these need to be plugged? They obviously let air in without being filtered or providing suction pressure.
Attachment KZ-airbox-holes.jpg not found
Clint
1980 KZ750 LTD H4
FSMaunual: kz.bike-night.com/media/GPz750-full.pdf
Stock except for:
New chain and sprocket (530?).
Dynatek Ignition
Manual tensioner on the way.
Buy JIS screwdrivers.
  • martin_csr
  • martin_csr's Avatar
Re: Airbox holes ports at bottom - what are these for?
02 Sep 2014 09:00 - 02 Sep 2014 09:02
#645911
No eBay APP ID and/or Cert ID defined in Kunena configurationThose holes are for routing the carburetor overflow tubing. Otherwise, plug the holes.
The Air Cleaner diagram shows a couple of grommets (NLA) & there are a couple of Y-fittings in the Carburetor diagram (Active).
Last edit: 02 Sep 2014 09:02 by martin_csr.
The following user(s) said Thank You: FaultedGeologist
  • FaultedGeologist
02 Sep 2014 20:39
#646056
Per my FSM and Haynes reading, I also thought they were for the carb overflow tubes (which my bike has never had since I purchased it). What is the recommended course of action - hoses to airbox or routed down behind engine to drip on ground?
Clint
1980 KZ750 LTD H4
Stock except for:
Dynatek Ignition
