Old Gas in Tank
- bugsinmyteeth
Old Gas in Tank
31 Aug 2014 17:41 - 31 Aug 2014 17:41
Most of the threads I searched related to cleaning a gas tank have to do with rust. Fortunately, I don't have a problem with rust. The issue is that the bike has been sitting for a couple of years with gas in the tank. I cleaned the carbs and they were gummed up bad. I figure the inside of the tank is probably gummed up some too. Of course I am going to empty the tank and put fresh fuel in. But before I do so, I want to clean out the tank so there is no residual varnish left in the tank.
Suggestions please.
Thanks.
Suggestions please.
Thanks.
Old School Is Cool!
1975 Kawasaki 900 (Z1B)
1982 Suzuki GS750E
Northern KY
1982 Suzuki GS750E
Northern KY
Last edit: 31 Aug 2014 17:41 by bugsinmyteeth.
- bountyhunter
Re: Old Gas in Tank
01 Sep 2014 01:25
Take the petcock assembly off and clean it separately. If the gas oxidized in the tank, it will be like sticky varnish. Fresh gas will help but may not get it all. A strong solvent like acetone is better but be careful not to let it hit any painted surfaces. You could also use a typical carb spray cleaner into the tank, same warning about paint damage.
- pete greek1
Re: Old Gas in Tank
01 Sep 2014 09:22
A safer approach would be using a gallon or 2 of white vinegar & shaking it around for a couple of days, wont harm paint like acetone will
Pete
Pete
