Starter Plungers Parts ???
- kzdcw
- 77' KZ1000A
28 Aug 2014 03:08
I'm starting to rebuild my carburetors on my 77' KZ1000A. The stater plungers aren't in to bad a shape but the plastic collars are nearly gone as with the rubber dust caps. I see that you can buy the rubber caps still but the collars appear to be obsolete?
I saw somewhere that someone had some collars made out of aluminum which to me was a perfect idea instead of the nylon. Does anyone know where you can purchase these collars whether nylon or aluminum???
Also, Is there any members that have a decent set of plungers they be willing to part with?
77' KZ1000A
- kzdcw
- 77' KZ1000A
Re: Starter Plungers Parts ???
28 Aug 2014 16:37
Talked to Mike Ames at Z1 Ent. today. Set me up with the right parts to order.
77' KZ1000A
29 Aug 2014 04:52 - 29 Aug 2014 05:01
Does Z1Ent have the plastic starter plunger collars? (16073-014). Thanks.
Edit: never mind --- found it. Z1Enterprises.com --- Choke Rod Collar Pull Nylon - ZSM073-014
Last edit: 29 Aug 2014 05:01 by martin_csr.
