Carbs floats
  • koloj
  • koloj's Avatar Topic Author
Carbs floats
24 Aug 2014 16:01
#645015
Well I measured carb floats they were about a 11/2 inch mark what should they be at on a 1980kz 750 4 cause now that have them set here bike won't stay running
  • martin_csr
  • martin_csr's Avatar
Re: Carbs floats
25 Aug 2014 07:13 - 25 Aug 2014 08:31
#645059
Setting the floats dry doesn't always result in the correct fuel level in the carburetors.
The service fuel level check is a more accurate measurement, since it will show the actual fuel level.
From the 750-4 pdf --- see diagram & table on page 156:
Service fuel level Standard = 4.0 +/- 1 mm below the bottom edge of the carb body (1980 models).
The measurement is different for some of the later 750s (e.g., 1982 = 3.0 +/- 1.0 mm).
Last edit: 25 Aug 2014 08:31 by martin_csr.
