Has anyone drilled out the primary jet on KZ440?
  • TimKz44082
  • TimKz44082's Avatar Topic Author
14 Aug 2014 06:06
#643907
From what I have found out there are two main jets on the keihin, a primary and a secondary. The secondary is under the needle and the primary is right next to it on the engine side. Under that primary jet is an emulsion tube that can get plugged up and will cause gas starvation. Is that starvation at lower rpms?. Once I am sure that emulsion tube is clear, I want to drill out the primary jet a bit. Has anyone done this to fix low rpm hesitation?
1981 KZ440 LTD
1982 KZ440 LTD
1974 Honda Trail 90
1982 Honda Express NC50
1982 Honda Trail 110
Electric scooter
  • bountyhunter
  • bountyhunter's Avatar
Re: Has anyone drilled out the primary jet on KZ440?
14 Aug 2014 12:03 - 14 Aug 2014 12:04
#643941
WAYYYY back when I was young, I drilled some jets to experiment and it's more trouble than it's worth IMHO.
On my bike, low RPM hesitation (stumble as throttle is opened) is most affected by needle position. The pilot jets also affect low RPM performance.
I have never worked on yours but that's how mine works.
Last edit: 14 Aug 2014 12:04 by bountyhunter.
  • TimKz44082
14 Aug 2014 12:27 - 14 Aug 2014 12:49
#643951
The reason I am thinking about drilling it out is because I bought a jet kit and it includes small drills to drill it out if needed to dial the carb in. the kit directions say to raise the needle with 2 washers to start out with, and install a 102 secondary main jet, no change to the primary at this time. Then a fuel air screw adjustment and a test run. If problems persist in the low rpm range, its time to drill out the primary main jet, a larger one is not provided. From what they are called, I am assuming that the primary main jet is the first jet to have an affect on the response, then the secondary kicks in? At what rpm do they both operate in? I think I am having a problem with the emulsion tube underneath the primary jet. I think it is plugged and I can't get it out right now. I'll soak the carb completely again and see if it will break loose. Has anyone taken it out somehow? Does it just drop out after you unscrew the primary jet or do you have to unscrew it also?
1981 KZ440 LTD
1982 KZ440 LTD
1974 Honda Trail 90
Electric scooter
Last edit: 14 Aug 2014 12:49 by TimKz44082.
