I had a thought for CV36 pilots (KZ440)
- Crazy Axe
13 Aug 2014 12:43
So I've got an 82 KZ440A LTD which has stock exhaust but cone filters instead of an airbox. Starts hard and I get a bit of stumble under low throttle. I opted to go up on the mains to, I think 190 if I recall right. I wanna put bigger pilots in it, but of course they are not easy to find. I've got a power sports junkyard about an hour away I am going to call and see if they can find something for me, but I had an idea.
Looking at the size of the pilots on the 82 CV36 carbs, and seeing what's available online, I see Keihin makes a 25 series jet. It looks very similar, only the tube is not as long. Has anyone tried these to get a little more fuel into the pilot circuit?
Here are some pics for visual comparison:
Stock pilot
25 Series pilot
Stock pilot
25 Series pilot
- Crazy Axe
Re: I had a thought for CV36 pilots (KZ440)
21 Aug 2014 08:59
Ok so I ordered some 25 series pilots, size 38. I will post back with news of if they work or not.
The following user(s) said Thank You: undiablo
- loudhvx
21 Aug 2014 09:29
The end of the emulsifier tube usually has to seal into a port. With it being so short, it won't reach the port. It will be open... not saying it won't work, but it will not be working as intended.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Crazy Axe
25 Aug 2014 12:36
Well the pilots came today. The 25 series are a different thread so I couldn't even try it. I ended up trying to make some intake "runner" tubes out of duct tape and coke cans, and they made no difference. Last I tried the old sock trick over the cones and now it runs considerably better. So I guess if anyone is stuck with cone filters on a kz440, put socks over the cones.
- pete greek1
25 Aug 2014 12:50
Crazy, you can call here & see if they have the pilot size your looking for
www.google.com/url?sa=t&rct=j&q=&esrc=s&...Fr3yF23eoRoN11MEOWnw
Pete
Pete
