Petcock leak
- LineArtist
Petcock leak
11 Aug 2014 20:12
I've been riding my 79/650 everyday and enjoying my time on 2 wheels. I noticed a small leak coming from the elbow at the fuel hose. The leak isn't a drip, but enough to shine up where the 90 elbow meets up with the petcock body. The elbow slightly rotates, and I'm guessing there is an o-ring and clip on the elbow (at least I'm hoping there is).
Just want to ask if this is a common problem and if I'm on the right track before pulling it apart to inspect and correct.
This is the stock petcock with a connected vacuum hose.
Thx
Thx
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
Re: Petcock leak
12 Aug 2014 05:46
The fuel nipple on mine was just press fit into the orifice (no o-ring or anything).
When it came out while removing the fuel line, I reistalled it w Permatex liquid metal.
That was several years ago --- no leaks. A good alternate product is Seal-All --- it's listed on the HomeDepot website, so I guess their stores have it.
- LineArtist
Re: Petcock leak
12 Aug 2014 16:36
Thanks, I'll need to pull the tank off on the next rainy weekend to do a final carb sync and will take care of the loose nipple. It started to act up after I installed a new fuel line and filter.
'79 KZ650B3 (stock)
'06 HD 883R
'06 HD 883R
