Idle Issues 83 Spectre 550
- calvinhobbesfan92
11 Aug 2014 11:26
Hey there guys, I have a question for you idling experts. I have a 550 Spectre that will only start on full choke if its been sitting a while. To start I put it on full choke and I have to blip the throttle. After that it climbs to about 3500 rpm and sits there. I can let it sit like that for a few minutes and then back off the choke to half or quarter and it dies out unless I blip the throttle. After about 15- 20 mins of riding I can start the bike on zero choke just fine.
without doing a full carb tear apart everything looks decently clean. Are my jets clogged? Do I need to run some sea foam thru the tank?
83 Kawasaki Spectre 550 Bobber
- nickleo373
Re: Idle Issues 83 Spectre 550
11 Aug 2014 12:51
Check your carb holder boots for vacuum leaks
1981 KZ550C LTD
"If you ain't first, you're last"
- willburrrr2003
12 Aug 2014 10:42
Sounds like carbs need cleaned...possible clog in the idle circuit?
Regards,
Will
Regards,
Will
Regards,
Will R.
Will R.
