float adjustment
  • Markovich
  • Markovich's Avatar Topic Author
float adjustment
31 Jul 2014 08:20
#642143
Hi all, well I find I need to adjust the float height on one of my carbs. My questions are 1) how have you done this with the carbs still on? 2) any rule of thumb for how much bend it takes to get a few mm? I'm a bit nervous about it as I don't want to mess things up. Thanks, Keith
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
  • Tomolu5
  • Tomolu5's Avatar
Re: float adjustment
31 Jul 2014 10:51
#642161
Search "clear tube method" it is the ONLY way to set float heights accurately. It can be done on the bike usually, and a teeny tiny amount of bend on the tang makes for a pretty good difference in fuel level. When you are satisfied with the fuel height, ty-wrap your clear tube to the Carb, and let it sit for 10 or 20 minutes, just to be sure no fuel is bleeding through.
If you find my "kz900 semi restoration" thread, I detailed the process somewhere in the middle. It is critical that you her the floats dialed in, as it affects all other aspects of jetting.
Cheers
Tom
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • Tomolu5
  • Tomolu5's Avatar
31 Jul 2014 11:05
#642163
In fact I will be setting up a rack of 28s for my bike in a few hours, I will chronically the process, and link it here this evening
Mine:
The following user(s) said Thank You: Markovich
  • Markovich
31 Jul 2014 21:11
#642225
Thanks for the assist. That will be very helpful indeed. Just what the doctor ordered. I used the clear tube method and found the level a little high that's why I asked. Great forum for us amateurs. :)
  • Tomolu5
  • Tomolu5's Avatar
31 Jul 2014 21:30
#642229
Guys have helped me, just passing the Buck, did you find the thread? I can't link it From my phone
Mine:
  • LineArtist
  • LineArtist's Avatar
01 Aug 2014 01:23
#642248
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
