Throttle and clutch cables
- jsnabbs
- 1981 kawiKZ440
24 Jul 2014 00:04
could someone tell me the part numbers for the throttle cables and all so the clutch cable for a 1981 440C
im guessing they should be shorter than those for the KZ440A, right
TIME TO TRADE IN THE PEDALS FOR SOME POWER
Re: Throttle and clutch cables
24 Jul 2014 07:01
KZ440C? Maybe you meant 440B? If yours is an Ltd, then the Standard cables are probably shorter. But I would figure out the overage of the current cables first & get measurements for the replacements.
You can find the part numbers at Kawasaki.com or Partzilla.
Z1Enterprises.com typically lists the lengths of the cables. Be sure to note the amount of slack --- if the replacement cable is less, it may not fit right. don't ask how I know. doh.
24 Jul 2014 07:27
Is your 440-C a "Z440-C" like the one below or a "KZ440-C"? Ed
Attachment 00007_2014-07-24.jpg not found
Last edit: 24 Jul 2014 07:57 by martin_csr.
- jsnabbs
- 1981 kawiKZ440
24 Jul 2014 08:32 - 24 Jul 2014 08:39
i dont see a difference, between the Z-440C and the KZ440-C but i have an untrained eye
My vin number says its a KZ440-C
Last edit: 24 Jul 2014 08:39 by jsnabbs.
