GPZ carbs
  • kawasaki750e
  • kawasaki750e's Avatar Topic Author
GPZ carbs
18 Jul 2014 18:17
#640549
So I just purchased a real frankenstien kz750 slash gpz 750. Its a kz L3 frame with a gpz motor. It runs like crap so after cleaning and checking the mains and pilots its running 36 pilots and 118 mains. So I put my 81 kz 750 e carbs on it and it ran perfect. So my question is are the gpz carbs a different mm carbs? I bought 125 mains for it the same as the kz carbs have. Hoping that helps.
  • baldy110
  • baldy110's Avatar
Re: GPZ carbs
18 Jul 2014 19:56
#640555
The GPz750 uses Mikuni BS34 carbs.
  • GPzEric
  • GPzEric's Avatar
Re: GPZ carbs
18 Jul 2014 21:35
#640565
The BS34's have an enricher, and no choke plate in the airway - the 750cc horsepower wars were in full-force, and they wanted to flow every bit of air they could.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
  • undiablo
  • undiablo's Avatar
Re: GPZ carbs
18 Jul 2014 23:49 - 18 Jul 2014 23:50
#640570
Mikuni BS34 did come on gpz750 and some models of kz750 and kz1000. Difference in main jet could be because of a completely different needle shape / size.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 18 Jul 2014 23:50 by undiablo.
  • kawasaki750e
Re: GPZ carbs
19 Jul 2014 18:41
#640641
Guessing that's the problem they are keihin carbs
  • Nessism
  • Nessism's Avatar
  • Away
Re: GPZ carbs
20 Jul 2014 11:45
#640699
Keihin and Mikuni use completely different jets. You can not compare jet sizes between them based on the numbers.
  • woodman
  • woodman's Avatar
Re: GPZ carbs
22 Jul 2014 16:00
#640984
Stock jetting and pilots have worked prefect on mine both with & without a 4-1 pipe on it for 32 years. Just backed the mixture screws out 1 turn more for the pipe. Don't just clean the jets, clean all the passages on the carbs too. Theres an excellent cleaning diagram on here but I don't recall who wrote it
