Hard starting when hot, or cold
  • dannyh
  • dannyh's Avatar Topic Author
05 Jul 2006 10:54
#59493
I used to have a problem where the bike would start up fairly easily, but would cut out on me after about 5 minutes of riding. Now my bike runs well, but has a hard time starting when it is 'cold' and 'hot'. However, when I get it started and ride it for a while, then turn it off and let it sit for a 1/2 hour or so, it starts right up. Any clues?
The carbs were just taken apart and put back together for the nth time. Petcock and fuel lines are good.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: Hard starting when hot, or cold
07 Jul 2006 11:15
#59973
Maybe change the plugs & clean the ignition contacts in the points or electronic ignition.
Mine did it too & this cured it for some reason, also cut the plug wires back about 1/2" to get into clean metal, I used dialectric grease on the wire ends to avoid more corrosion in the future.
