Fuel Leak? Please help!!
  • Stncld2
  • Stncld2's Avatar Topic Author
17 Jul 2014 11:26
#640400
I bought my first bike a few months ago. I have a 1980 Kawasaki KZ750 and i have a fuel leak. The problem is it is leaking from under a black box that feeds into the 4 carbs. It is leaking out of the bottom of this "box". I dont know what the name of the box is. It is black with grooves on the sides and it is like hard plastic or rubber. I need to know if I should go through the carbs or is this "box" the problem. Also this seems to be causing it to idle real low. Any thoughts?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Fuel Leak? Please help!!
17 Jul 2014 11:37
#640401
Is it the airbox where the air filter sits under the seat?
  • Scotch
  • Scotch's Avatar
17 Jul 2014 11:52
#640403
Hi , your carb float bowls have overflows which feed into your air box . Your leak is coming from there which means you will have to remove your carbs and check your float heights and possibly clean your float needle and seat . Had this happen to me on my kz750 ltd h2 , found my float needle sticking open ! .
Good luck.
1981 kz750 H2 ltd .
  • gengomerpyle
  • gengomerpyle's Avatar
17 Jul 2014 16:36
#640428
i hope you dont have you petcock set on "PRI" if you do the leaking from the airbox will be the least of your worries
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
The following user(s) said Thank You: PLUMMEN
