- Thank you received: 33
Carb sync screws
- nickleo373
12 Jul 2014 14:11 #639846
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Carb sync screws was created by nickleo373
Hey everyone
I just ordered some new carb holder boots to get rid of some vacuum leaks. I want to sync the carbs after I install the holders but I noticed the tiny screws on the top of my TK-22s are frozen in place. I've tried penetrating oil with no luck. Is there a way to free them up without completely destroying the carbs?
1981 KZ550C LTD
- loudhvx
- Thank you received: 1616
12 Jul 2014 15:25 #639862
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Carb sync screws
Small vice-grip, maybe.
The real problem is you probably don't have JIS screwdrivers. Get them before doing anything on the inside of the carbs, especially if you try topull out the flat-head screws that hold the thrttle arm to the throttle shaft. Those are notoriously tight. Don't use an impact driver on them.
1981 KZ550 D1 gpz.
Other links.
