77 kz650 advise
  • Scubagli
  • Scubagli's Avatar Topic Author
77 kz650 advise
24 Jun 2014 11:16 - 24 Jun 2014 12:05
#637854
I recently got this bike, it has a bunch of electrical issues which I have gotten under control. Now I'm dealing with carb issues I think. The bike starts and idles with just under 1/2 choke, will throttle up in neutral, but put it in gear and it stalls without about 4krpm. The bike came without an air box it put pods on, it has a 102 main and a 50 primary. I'm guessing it needs rejetting, I have very little experience with carbs any help would be appreciated, I do not want want to purchase a stock air box unless it is cheap so if anyone has one let me know. The carbs have been cleaned and I have no vacuum leaks, I haven't checked points/timing or valves, what is the correct order to check things out? Forgot to mention 4 into 1 exhaust.
Last edit: 24 Jun 2014 12:05 by Scubagli.
  • baldy110
  • baldy110's Avatar
Re: 77 kz650 advise
24 Jun 2014 13:08 - 24 Jun 2014 13:12
#637867
The carbs should be VM24's and if so what is this #50 primary jet?
The carbs are still dirty, If you have VM 24's take the carbs back off and clean them thoroughly, pay attention to the small passagesways in the carb bodies. Make sure they are all clean and clear. With a 4 into 1 pipe swap in a set of 17.5 pilot jets, go up to 105 for the main jets and raise the needles one position. That should get you close..
Last edit: 24 Jun 2014 13:12 by baldy110.
  • Scubagli
Re: 77 kz650 advise
24 Jun 2014 13:41
#637871
Thanks.
  • Scubagli
Re: 77 kz650 advise
25 Jun 2014 07:50
#637954
On the needles is it 1-5 bottom to top or 1-5 top to bottom? Right now they are set 2 from the bottom.
Attachment ImageUploadedByTapatalk1403707801.709735.jpg not found
Re: 77 kz650 advise
25 Jun 2014 07:53 - 25 Jun 2014 07:53
#637956
The groove numbers start at the top. Your pic shows the clip in groove #4 . Ed
Last edit: 25 Jun 2014 07:53 by 650ed.
  • Scubagli
Re: 77 kz650 advise
25 Jun 2014 08:23
#637959
Thanks what position is "stock"?
  • baldy110
  • baldy110's Avatar
Re: 77 kz650 advise
25 Jun 2014 09:57
#637964
Stock is the middle one, yours are set up already for what you need.
  • Scubagli
Re: 77 kz650 advise
25 Jun 2014 10:22
#637965
Thank you.
Re: 77 kz650 advise
25 Jun 2014 11:18 - 25 Jun 2014 11:19
#637967
Scubagli wrote: Thanks what position is "stock"?
4th groove is stock. See image below. Ed
Attachment 00004_2014-06-25-2.jpg not found
Last edit: 25 Jun 2014 11:19 by 650ed.
  • Scubagli
Re: 77 kz650 advise
25 Jun 2014 12:10 - 25 Jun 2014 12:13
#637971
So I should go to 5. Thanks 650ed
I see the air screw adjustment is 2 +\- 1/4 turn, would that stay the same, logic says it would be less....
Last edit: 25 Jun 2014 12:13 by Scubagli.
