HELP ! K&N filters on z1000st 1980
- Glejol
21 Jun 2014 18:39
Hi there!
I just bought a 1980 z1000 st, and I changed the air filter box with 4 K&N filters. But now it want run right on low rmp's
only on full throttle, does anybody know what the problem can be? I adjusted the mixture screw 3rmps out. Please help.
Re: HELP ! K&N filters on z1000st 1980
21 Jun 2014 18:56 - 21 Jun 2014 18:56
The problem is that you replaced the airbox with individual filters. There is no "mixture"screw that will make the bike run well. You need to either put the airbox back on the bike or start learning how to rejet the carbs. Do a search using the word PODS on this site; you'll see thousands of postings on the subject. Ed
Last edit: 21 Jun 2014 18:56 by 650ed.
The following user(s) said Thank You: Glejol
21 Jun 2014 19:12 - 24 Jun 2014 10:55
A Dynojet kit will make the rejetting task easier. They don't list an exact match for an ST, but I suspect the regular KZ1000 kit will work fine. Just be careful to get the type for CV carbs, not VM's.
Edit: made a mistake, it should be VM and NOT CV (got it backwards). :silly:
www.dynojet.com/jetkits/motorcycle/kawasaki.aspx
Last edit: 24 Jun 2014 10:55 by Nessism.
23 Jun 2014 08:09Nessism wrote: A Dynojet kit will make the rejetting task easier. They don't list an exact match for an ST, but I suspect the regular KZ1000 kit will work fine. Just be careful to get the type for CV carbs, not VM's.
are you sure a 1980shaft has cv carbs?
my 1980z1r has slide carbs not cv's.
- bassie10
23 Jun 2014 21:38
My bad on the CV's. Sorry. Dynojet kit is the stuff though.
24 Jun 2014 05:58
can't go wrong with dynojet thats for sure.
- Glejol
