Question about 28mm pumper carbs
- peter1958
- Banned
Re: Question about 28mm pumper carbs
19 Jun 2014 15:36
cavanaughracing.prophpbb.com/topic231.html
The real deal
www.kzzone.com/
The following user(s) said Thank You: 68dave
- Tomolu5
19 Jun 2014 20:45peter1958 wrote: cavanaughracing.prophpbb.com/topic231.html The real deal
That's the write up I was looking for, read it again, Thanks!
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- 68dave
20 Jun 2014 14:23
Yea thanks, i read it twice already.
Green 1976 KZ900 & Z1 look-a-like 1976 KZ900 Baltimore, Md.
- 68dave
29 Jun 2014 14:46
I just installed the set of 28 pumpers that i purchased from Jim @ Redline and took it for a quick blast on the highway. They performed great on the highway but lower rpm's around the nieghborhood i would get a slight PSSHH sound from the carbs, only did it like twice but it was there. I installed brand new manifolds, ngk B8ES plugs gapped at 32 and k&n oval air filters at the same time i installed the carbs. Runnin fresh 93 octane gas. I'm gonna ride it to work, maybe it was just a fluke.
- pete greek1
29 Jun 2014 15:04
68dave, did you tell Jim you were going ta use Pods ? he would have to jet them for -em,, some times it takes a few different jet settings to get them perfect, when he redid my engine, & sold me the R S 34 Mikuni flatslides I picked up the bike & it ran like shit, & had to bring it back for him to fix it
Pete
Pete
- DFIGPZ
29 Jun 2014 16:05
28mm carbs will be fine I have put them on a number of 1075 engines with ported heads cams etc they are plenty not worth the money to go with 29mm smoothbores In my opinion. i have done plenty W/O issue but I also dyno tune them with a wideband.
1984 750 Turbo
- 68dave
29 Jun 2014 17:37
Jim asked me all the specs on my bike and i told him k&n air pods, dyna inigition/coils and a kerker w/baffle but i did tell him that a new V&H was in the near future. It runs real good and pulls hard. Only issue is that popping PSSHH sound at low rpm's. I'm gonna run it back & forth to work for a couple days then pull the plugs to see how she's runnin.
- DFIGPZ
29 Jun 2014 20:45 - 29 Jun 2014 20:46if you are going to a V/H header then you might as well wait till its installed it will require different jetting as the V/H has large radius bends out of heads to a smaller diameter collector verses the Kerkers short radius bends and large diameter collector in short V/H much better street pipe Kerker more for high rpm work.68dave wrote: Jim asked me all the specs on my bike and i told him k&n air pods, dyna inigition/coils and a kerker w/baffle but i did tell him that a new V&H was in the near future. It runs real good and pulls hard. Only issue is that popping PSSHH sound at low rpm's. I'm gonna run it back & forth to work for a couple days then pull the plugs to see how she's runnin.
1984 750 Turbo
Last edit: 29 Jun 2014 20:46 by DFIGPZ.
