KZ750 spectre jetting?
- Racewayelko
08 Jun 2014 18:51
So I (two days ago) decided to upgrade to pod filters on my bike, not so much for performance
as it was cheaper to do then get new intake boots. The issue I have now is it runs super lean (go figure, give a bike more air and it runs lean) so much as I can't ride it up the driveway. My question is, what should I do? Turn the mix screw out? rejet? (if so to what) Shim the needle? all of the above? Thank you all
Keep it rubber side down everyone
Klx 110, TTr125, TTr250, 1982 kz750-N1 (Spectre), Xt-350 (soon to be the new home of a Kz550 engine
Re: KZ750 spectre jetting?
08 Jun 2014 18:55 - 08 Jun 2014 18:56
Take a look at the listing below. It describes how to find info on pods. BTW, I suspect you will find new intake boots would have been a bargain.
www.kzrider.com/forum/4-electrical/59374...-stay-running#633806
Last edit: 08 Jun 2014 18:56 by 650ed.
- Racewayelko
08 Jun 2014 19:38My dealer quoted me 66.09 when pods were 40.00650ed wrote: BTW, I suspect you will find new intake boots would have been a bargain.Ed
08 Jun 2014 20:21
Not trying to rip a new one :laugh: You will end up buying jets, and quite possibly a few different flavors or a jet kit before finding a combination you can live with. Finding a combination that will let the engine run as well as the air box throughout the entire rpm range has been a challenge for many folks. I'm not saying it is impossible, but getting it done with the first set of jets is unusual. That's the reason for the comment about new intake boots being a bargain compared to pods. The cost of the pods is only part of the overall cost of eliminating the air box. Maybe someone here who has already gone through the rejetting exercise with the same model bike can give you a starting point. Ed
The following user(s) said Thank You: Racewayelko
- Racewayelko
08 Jun 2014 20:37
kzrider.com/forum/3-carburetor/206216-go...gestions-for-a-kz750
i think i will use this as a baseline. (70/140) but where to find them?
09 Jun 2014 04:41
- undiablo
09 Jun 2014 05:55
Yep, 35 - 70 - 140 is the rejet recommended for years by WiredGeorge.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
