Correct float height spec needed for 1982 KZ750 H3
  • RickP
  • RickP's Avatar Topic Author
04 Jun 2014 19:29
#635387
I'm rebuilding the carbs from my 1982 KZ750 H3 LTD and need the correct float height and air mix screw turns open. These are Keihin carbs, and I believe they are CV34 carbs.
Thanks!
Re: Correct float height spec needed for 1982 KZ750 H3
04 Jun 2014 19:48
#635389
Here’s a cut & paste from the KZ750-Four Kawasaki Service Manual Supplement for the KZ750-E3; L2; H3; and R1 models. Ed
Attachment 00006_2014-06-04-2.jpg not found
  • RickP
04 Jun 2014 20:03
#635391
Thanks, but I don't have the special gauge they mention. I'm looking for the dry height I can set before putting the float bowls back on.
  • Tomolu5
  • Tomolu5's Avatar
04 Jun 2014 20:12
#635394
Search clear tube method on this site, or YouTube, or even Google it for that matter. There's not anything exotic needed, just a clear tube, and a way to.mark a reference line on the Carb bowl
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
05 Jun 2014 00:23
#635413
You need to get yourself a copy of the FSM for your bike but here you go
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • RickP
05 Jun 2014 04:30
#635416
Thanks! Just what I was searching for! Another question - what is the range of fork air pressures for this bike? It has the "air ride" front suspension.
  • mopguy
  • mopguy's Avatar
05 Jun 2014 07:40
#635430
The manual I have is for a KZ750 FOUR H1 , the standard is 8.5 PSI however it can range from 7.11 to 14.22 PSI, hope this helps.
05 Jun 2014 08:46
#635440
Perhaps a free manual download from one of these sites will suffice until acquiring a genuine factory FSM covering the bike at hand.
kz.bike-night.com/manual.html
scroll down to "The Bible"
www.mediafire.com/download/tgyn0uywyny/K...ki+GPz750+Manual.zip
Good Fortune! :)
