1982 kz550
  • CoN2389
  • CoN2389's Avatar Topic Author
1982 kz550
01 Jun 2014 14:42
#634905
So I'm pretty sure the carbs have not been touched since the factory. How hard would it be to clean the carbs my self. Guy at the local shop wants $250. I don't wanna swing that right now. The bike runs but it drags. I've never done carb work but I do have the cliymer manual. So any pointers? Should I just have them do it? Or is it fairly simple for someone that dosnt know a whole lot on bikes!
Thanks
-CoN2389
  • CoN2389
Re: 1982 kz550
01 Jun 2014 17:10
#634927
So I took then off. Not that bad! Any way is that color on the outside a bad sign? Or is that normal for 30+ years?
-CoN2389
  • CoN2389
Re: 1982 kz550
01 Jun 2014 17:22
#634932
Also is that one suppose to be missing? This is with the "choke" on.. I think there should be a flap there
-CoN2389
  • GPzEric
  • GPzEric's Avatar
Re: 1982 kz550
01 Jun 2014 20:00
#634948
It's got a broken choke flap - a pretty common failure on these models.
First, take out the air filter, and scrutinize inside the airbox, as there's a chance the broken part is lying in there.
If you can't find it, look inside the intake port and see if it's in there -
It can also blow through the engine and cause much damage, or blow through the engine and damage nothing.
If you want a complete flap let me know, as I have a few spares.
good luck - Eric
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
  • nickleo373
  • nickleo373's Avatar
Re: 1982 kz550
01 Jun 2014 20:41 - 01 Jun 2014 20:43
#634956
That choke flap will have to be replaced for the choke to function. Without it the vacuum will be unstable and cause the idle to rev out of control with the choke on. It looks like your float bowl gaskets may have been leaking at some point which is another common problem. The carbs themselves look fine though. Tk22s are pretty simple to work on
1981 KZ550C LTD
"If you ain't first, you're last"
Last edit: 01 Jun 2014 20:43 by nickleo373.
  • CoN2389
Re: 1982 kz550
02 Jun 2014 03:58
#634969
Thanks guys I'll see if I can find the flap and let you guys know what I come up with!
-CoN2389
  • martin_csr
  • martin_csr's Avatar
Re: 1982 kz550
02 Jun 2014 06:38
#634985
KZRider loudhvx's --- motorcycle stuff page .... Choke flap link near bottom of page.
Re: 1982 kz550
02 Jun 2014 07:00
#634988
One other word to the wise - if you decide to take the carbs apart to clean them either do one carb at a time OR use 4 plastic tubs to keep each carb's parts separate. The carb parts tend to wear together so mixing parts between carbs can result in problems. Ed
The following user(s) said Thank You: CoN2389
  • CoN2389
Re: 1982 kz550
03 Jun 2014 16:01
#635200
Should each carb have a float needle? Cause I'm only seeing one out of the 4 carbs...
-CoN2389
Re: 1982 kz550
03 Jun 2014 16:06
#635201
Yes, they should each have a float and float valve including the needle. Ed
Re: 1982 kz550
03 Jun 2014 16:14
#635202
Here's a carb diagram. Ed
Attachment 00006_2014-06-03.jpg not found
  • CoN2389
Re: 1982 kz550
03 Jun 2014 17:09
#635217
That's the thing I have only found 1 and before taking all this apart the bike ran. Is it possible to run with out them?
-CoN2389
