would these carbs fit my gpz1170
- ninjarider
28 May 2014 18:52
No eBay APP ID and/or Cert ID defined in Kunena configurationHi every one iam looking at buying these gs1100 carbs for my gpz i just want to be 100 percent sure they will fit before i buy them? also if i get these what dynojet kit would be the best to get to work with my bike? because if iam right these are bs34s so theres quite a few options for jet kits!
thanks in advance josh
- baldy110
Re: would these carbs fit my gpz1170
29 May 2014 09:27
Yes they will fit however there is NO WAY I would pay that kind of money for BS34 carbs.
- ninjarider
29 May 2014 18:16
So am I better off.buying the vm28 pumpers for that price there is not alot to be had in the UK.for that price there is company that sells rebuilt sets of bs34s I know for £265 SO I thought of.the.ones.on.eBay.as.cheap
- Cynjut
30 May 2014 08:11
Unless you're putting those 34s in a bike with a factory airbox and reasonably stock exhaust, getting them set up to work is going to be a challenge. A set of vm28s would be a much better choise, as would a set of 29s. For the money, you may also want to look into a set of modern RT34 carbs (IIRC).
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- ninjarider
30 May 2014 08:25
Thanks.for.the.info the bikes got a 1170 kit on it with a straight through harris pipe and would be running.pods!
Do you mean rs34 carbs
Thank again josh
Thank again josh
- Cynjut
30 May 2014 08:54
I was thinking TM Flat Sides, but then remembered RS, then doubted myself and ended up with neither. 8-0
There have been a few people extolling the virtues of the TM Flat Sides lately. They say they clatter a little bit, but are very good carbs.
A set of RS34 carbs would probably work just as well. Good quality, available new from Sudco, years of performance have made them a good carb for your application.
Because of the way the BS34 carbs work, hooking them up in anything but a stock situation is really, really challenging. You can get them to work at high RPMs, but you'll have stumbles and diminished power production at the low end. If you tune them so they work well at the low end, they punk out and get seriously lean as you move up the power band. The intake system designed around these carbs was done deliberately and changes to the parameters of that system negatively effect their performance.
1977 KZ-1000 A1
- ninjarider
30 May 2014 10:23
It had a set of bs34s on it when my dad was ill.
It dynoed with them and as you say it ran like crap on the bottom.but was real sharp up top 115bhp it ran with These!
Iam just on a realy tight budget at the moment as iam trying to put it on the road in time for the anniversary of my dad's death and take it to the Silverstone Motogp on a memorial ride. If I could afford a set of rs34s I.would I think it will end up being some vm28s unless a set TMs come.up or the suzuki gsxr vm29ss carbs!
What throttle cable set up do i need for vm28s is it a push pull
Thank.you for your help
- Cynjut
30 May 2014 12:49
Pull only or push-pull. The cable end is a threaded barrel that attaches to the bracket above the throttle halfmoon.
1977 KZ-1000 A1
- ninjarider
31 May 2014 05:23
Do they still spring back Ok with just a pull cable then
31 May 2014 09:31 - 31 May 2014 09:35ninjarider wrote: Do they still spring back Ok with just a pull cable then
When everything's working properly, the 2nd throttle cable isn't a functional requirement.
For many years, motorcycles had only one throttle cable and relied on a carb return spring -- sometimes much weaker than a typical KZ carb return spring -- to lower the throttle slide upon closure of the throttle grip.
Some folks have installed a weaker carb return spring (hardware store item) to reduce hand and wrist fatigue at continuous cruising throttle positions.
Others have removed the spring altogether and relied on using the 2nd cable to close the throttle (caveat: racing engine in a tip-over situation), which affords very easy throttle control for even a 90# weakling.
With otherwise as-new components, a weak carb return spring should return the carb to idle position without any throttle cable attached to the carb.
Last edit: 31 May 2014 09:35 by Patton.
