KZ-440 "aftermarket" airbox build instructions.
- Cynjut
28 May 2014 14:24 - 28 May 2014 14:25
One of the contributors at the Kawasaki Motorcycles forum just finished putting together a workable replacement airbox for the KZ-440. I don't know if he's a member here, but this is too cool to not post it here as well. This will be excellent news for KZ440 riders that struggle with the vagaries of the stock carbs on the 440 and don't have and can't find replacement airboxes.
Instructions for "aftermarket" KZ440 Airbox
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Last edit: 28 May 2014 14:25 by Cynjut.
- bountyhunter
Re: KZ-440 "aftermarket" airbox build instructions.
28 May 2014 15:02
Interesting. Sort of a dual pod kind of thing. I wonder if the airflow is similar to stock airbox.
- undiablo
28 May 2014 15:06
Very nice home made filter replacement!
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Cynjut
29 May 2014 13:12bountyhunter wrote: Interesting. Sort of a dual pod kind of thing. I wonder if the airflow is similar to stock airbox.
He says that the performance is very close to the original. With everything else 'stock', it runs a little rich, but with a higher performance 4-into-1 exhaust, he says it works almost the same as stock.
1977 KZ-1000 A1
- Balazs
29 May 2014 20:37 - 30 May 2014 04:40
Hi Guys,
Just to confirm, the filter flows very close to that of the stock airbox. Close enough to maintain OEM jetting on the carbs. The richness Cynjut mentioned was due to my exhausts being baffled up for a noise test. These have since been changed and it appears to be running nicely now
Here is the bike: kzrider.com/forum/11-projects/592782-kz440-ltd-cafe-project
Last edit: 30 May 2014 04:40 by Balazs.
The following user(s) said Thank You: Jbosh
- Jbosh
- 1982 Kz440 ltd D4
27 Sep 2014 09:41
:woohoo: Balazs! Nice work! Where did you get the filter membrane from?
As long as I get to learn something, I'm happy!
- Balazs
03 Oct 2014 18:46 - 03 Oct 2014 18:47
The filter is a complete unit to suit Dellorto and Weber side draft carbs typically used on worked VW beetle motors etc. Bought off 3bay!
Check the link back to kawasakimotorcycle.org. All of the details are there
Last edit: 03 Oct 2014 18:47 by Balazs.
