Stock airbox and mac4into1, what jetting?
  • ShouterVW
  • ShouterVW's Avatar Topic Author
27 May 2014 20:56
#634242
Okay the bike is an 81 650 with vm24ss carbs. Currently I have 17.5 pilots and 102.5 mains. I'm not convinced this is the right combo. I am no tuning expert, but it is a little doggy. What would be a good combo? Thanks
  • azman857
  • azman857's Avatar
Re: Stock airbox and mac4into1, what jetting?
27 May 2014 21:17 - 27 May 2014 21:21
#634243
deleted
Last edit: 27 May 2014 21:21 by azman857.
  • ShouterVW
28 May 2014 09:13
#634293
It idles well, but there's a definite hesitation when I twist to full or near full throttle. It stumbles stumbles, then catches up and really goes.
28 May 2014 10:20
#634298
Have you tried the stock 15 pilot jet? Ed
28 May 2014 11:28 - 28 May 2014 11:34
#634304
ShouterVW wrote: It idles well, but there's a definite hesitation when I twist to full or near full throttle. It stumbles stumbles, then catches up and really goes.
Fresh clean air filter?
Spark plug reading?
Fuel levels per clear tube tests?
Jet needle clip in stock position?
Timing advancer lubed and functional?
Good Fortune! :)
Last edit: 28 May 2014 11:34 by Patton.
  • Cynjut
  • Cynjut's Avatar
28 May 2014 11:59
#634308
What he said. I'd start with the timing advancer, but the rest of these things need checked as well.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • ShouterVW
28 May 2014 20:56
#634384
It is a clean air filter, jet needles are in stock and only position they can be in. Although, there is a thick and thin shim on the top and bottom of the needle clip. I have the thick one on top, and thin one on bottom. Maybe it needs to be the other way? How to know for certain? Timing advancer is free and functional. I checked my float heights awhile back but probably should do it again. As for the plugs, I will pull tomorrow and share my findings
29 May 2014 05:56 - 29 May 2014 05:57
#634415
You sated "Currently I have 17.5 pilots." Have you tried the stock 15 pilot jet?? Ed
Last edit: 29 May 2014 05:57 by 650ed.
  • ShouterVW
29 May 2014 08:47
#634436
I have not, I upped the pilots assuming it will run better with the 4into1. I will try the stockers
  • Cynjut
  • Cynjut's Avatar
29 May 2014 13:06
#634479
With the VM carbs, you don't generally need to rejet for new exhaust unless you completely open them. The only time you need to jet up is if you swap out the stock airbox for pods.
1977 KZ-1000 A1
  • ShouterVW
29 May 2014 14:29
#634502
Sounds great. I'll out stockers back in on pilots and mains
