carb sync
  • hotdogg
  • hotdogg's Avatar Topic Author
  • 1982 kz750 spectre
carb sync
23 May 2014 21:41
#633726
ive got a 1982 kz750 spectre..and I also have a carb sync tool with 4 gauges.. can anyone tell me where to hook it in..I looked around the carbs and there is no plugs but 3 of the 4 have vacume ports for other things..
1982 kz750 spectre
  • martin_csr
  • martin_csr's Avatar
Re: carb sync
24 May 2014 00:26 - 24 May 2014 00:27
#633738
You have to disconnect the 3 lines from the vacuum ports & remove a vac cap, probably on carb #3.
#2 probably has the vac line for the fuel tank petcock and #1 & #4 probably have the clean air system vac tubing. I guess you should cap the clean air tubing?
Last edit: 24 May 2014 00:27 by martin_csr.
The following user(s) said Thank You: Yangdawg
  • pscycle
  • pscycle's Avatar
  • MMMMHMMMM
Re: carb sync
25 May 2014 01:52 - 25 May 2014 17:07
#633879
Hey bud is the bike running good? or is she acting up on you?
pscycle927
Last edit: 25 May 2014 17:07 by pscycle.
  • hotdogg
Re: carb sync
25 May 2014 21:44
#634000
I found the plug over the vacume nipple thing thanks. And the bike is running pretty bad I found it in a barn.
1982 kz750 spectre
  • pscycle
  • pscycle's Avatar
  • MMMMHMMMM
Re: carb sync
26 May 2014 22:54
#634109
If it was in a barn it will most likely need the carbs gone through and cleaned. If the rack has not been torn apart I doubt they are out of sync. Just my thoughts. good luck keep us posted.
pscycle927
  • hotdogg
Re: carb sync
27 May 2014 08:42
#634150
Alredy been through the carbs. Still won't idle. The previous owner for some reason adjust all the pilot screws so I'm just trying to tune it. I have so little time it's taking a long time to get it right
1982 kz750 spectre
  • martin_csr
Re: carb sync
27 May 2014 10:03
#634153
Just an FYI: there probably isn't a factory specified Pilot Screw setting for the US models, but for the Canadian models it's probably 2 turn out from seated (seat them gently - the tips are fragile).
If you need a service manual, search eebbaayy for KZ750 Shaft Manual. There are several listed.
Here's a site w a manual & wiring diagrams for the chain drive models.
The carb info may be helpful, though. mbsween.bike-night KZ750L3 page .....
Scroll down & click "The Bible" link.
Note: not really applicable to your 750-N1, but some of the wiring diagrams are mislabeled in the links.
An H2 is a 1981 model, the H3 is an 82, & the H4 is an 83. (search tags mbsween KZ750L3)
