rejett? with sportster mufflers
  • shawn stangel
  • shawn stangel's Avatar Topic Author
22 May 2014 14:06
#633490
i have a 79 kz400 and the back end of my pipes are roached,and i happened to have a set of stock sporty pipes tnhat have the cross member,im wanting to use the muffler only and was wondering would this normaly need to be rejetted?
  • martin_csr
  • martin_csr's Avatar
Re: rejett? with sportster mufflers
22 May 2014 14:20 - 22 May 2014 14:20
#633498
Do the mufflers have any baffles or packing or anything inside?
Last edit: 22 May 2014 14:20 by martin_csr.
  • shawn stangel
22 May 2014 17:48
#633546
yes there is baffles that have been opened up slighty
  • Jrbrownie00
  • Jrbrownie00's Avatar
23 May 2014 04:18
#633600
I'd be willing to be you could get away with not jetting. You can put a 4-1 pipe with a baffled exhaust on a lot of bikes and no jetting is required so with you just replacing muffler I'd say your safe. Cheers.
82' kz750 ltd.
The following user(s) said Thank You: shawn stangel
  • koolaid_kid
  • koolaid_kid's Avatar
23 May 2014 04:59
#633605
I agree, with such a simple change I doubt you would need to rejet. Be sure and read your plugs after riding it a bit with the new pipes.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
