650D2 install carb intake boots
- Dozer
20 May 2014 13:20
Guys...on the 650 D2 the old intake tubes were as hard as rocks. I bought a new set...nice and soft. However they are proving to be a PITA to install with the carbs on the bike. Anyone have any tips? I am tired of getting my hands chewed up from working inside of that airbox...
thanks
D
thanks
D
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: 650D2 install carb intake boots
20 May 2014 14:08
It helps to warm them in hot water prior to installation. I also found that a light coat of grease makes them a little more slippery and easier to install. Ultimately I called on the assistance of my wife (it's her bike anyways!) and she put them on :blush: She has smaller hands than I do :lol: Good luck! Paul
The following user(s) said Thank You: Dozer
- pete greek1
20 May 2014 14:55
Like Paul said, or you can ask your wife/girlfriend to
use her hair dryer to heat-em up & make-em more plyable
Pete
Pete
- Dozer
20 May 2014 16:27
Okay...heat and a little lube..like KY?? LOL I have a heat gun and some DC4 silicone lub. I'll give that a try. I am getting ready to start it up again, adjust the pilot needles and see if I can sync these carbs.. If this motor is like other multi carb bikes I've worked on, the air inlet components and filter need to be completely assembled to get the best results.
Thank you
D
Thank you
D
- Dozer
20 May 2014 16:33
I'm gonna give it a try as mentioned above, but getting my wife to help will never happen...she absolutely hates motorcycles and doesnt want to be around them in any way, shape or form. So I am pretty much on my own. If I get it all together I'll report back with the results.
Thanks Pete
D
Thanks Pete
D
- Dozer
21 May 2014 10:42
Thanks guys...the hot water trick worked great
