Throttle cable from other kz's will it work?
- justwannaridekz250
14 May 2014 15:17
Will a throttle cable from a 1980 kz 550 (or any other same year kz bike) fit on a 1980 kz 250?
www.dimecitycycles.com
'05 TTR90
'08 CRF100F
'85 XL350R
'80 KZ250
Current projects
'85 XL350R -street tracker
'80 KZ250 -brat racer
-Gabe
'05 TTR90
'08 CRF100F
'85 XL350R
'80 KZ250
Current projects
-Gabe
Re: Throttle cable from other kz's will it work?
14 May 2014 15:41 - 14 May 2014 15:42
Per kawasaki.com
KZ250-D1 (KZ250) (1980) Throttle Cable, Part No. 54012-1060, was used on the following three models:
KZ250-D2 (CSR) (1981)
KZ250-L1 (CSR Belt) (1982)
I don't know which if any other model throttle cable might fit.
If interested:
Could also check with MotionPro for price of a custom cable.
Could Google the part number, but the few parts houses I looked at showed the part as no longer available.
justwannaridekz250 wrote: Will a throttle cable from a 1980 kz 550 (or any other same year kz bike) fit on a 1980 kz 250?
Per kawasaki.com
If interested:
Last edit: 14 May 2014 15:42 by Patton.
The following user(s) said Thank You: justwannaridekz250
14 May 2014 16:54
I would highly recommend buying the cable that was made for your model bike rather than trying to force fit the wrong cable. Ed
14 May 2014 17:17
Okay thanks for the info, I'll try it anyways as I already bought it. Wish me luck!
'05 TTR90
'08 CRF100F
'85 XL350R
'80 KZ250
Current projects
-Gabe
'05 TTR90
'08 CRF100F
'85 XL350R
'80 KZ250
Current projects
-Gabe
15 May 2014 05:25
If the handlebars are not stock (lower or whatever), then the stock cable may be too long.
I would figure out the approximate needed length & compare the stock ends to the various cables available at the Z1Enterprises.com. The slack needs to be at least the same as stock - a little more slack might be okay, but not less. don't ask how I know. doh.
Alternatively, assuming you have the stock throttle grip assy & stock carburetors, you could figure out the desired length, then get a custom cable made - either MotionPro or Barnett (I guess barnett makes custom cables?).
15 May 2014 07:41
I fitted the throttle cable last light and found it didn't fit. It wasn't too long but the main problem is that it doesn't fit Probably today, I'll use a drill and try to make the threads a little bigger as this bike will get new controls (eventually). Anyone know where I can get controls for this bike if things go wrong?
'05 TTR90
'08 CRF100F
'85 XL350R
'80 KZ250
Current projects
-Gabe
'05 TTR90
'08 CRF100F
'85 XL350R
'80 KZ250
Current projects
-Gabe
15 May 2014 07:47
If the cable doesn't fit into the throttle grip assy &/or carburetors, either it is the wrong cable, or the stuff on the bike is not stock. You'll need to figure that out.
15 May 2014 09:39 - 15 May 2014 09:43justwannaridekz250 wrote: I fitted the throttle cable last light and found it didn't fit. It wasn't too long but the main problem is that it doesn't fit Probably today, I'll use a drill and try to make the threads a little bigger as this bike will get new controls (eventually). Anyone know where I can get controls for this bike if things go wrong?
Are you kidding? If you ask me you are BEGGING for trouble! As I said before I highly recommend buying the cable that was made for your model bike rather than trying to force fit the wrong cable. You will end up wrecking more stuff which will cost you more money. Please don't be offended, but why are you so determined to create a problem rather than simply replace the part? Why not simply install the correct part and move on instead of creating a problem? Do yourself a huge favor and back away from the drill and buy the cable that is made for the bike - you will not regret doing so.
Last edit: 15 May 2014 09:43 by 650ed.
- KZ802
21 May 2014 05:57
When I changed style handlebars I went to my local kawi dealer with my old one. I needed a shorter cable. They took my old one and went in the back and looked until they found one the size and style I needed in stock. 15 bucks later I had the correct cable with no guesswork. Just my 2 cents.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
1978 KZ1000 LTD
1976 KZ900 A
