81 Kz650 hangs on revs.
Re: 81 Kz650 hangs on revs.
19 May 2014 06:15 - 20 May 2014 05:57
Anything's possible, but the spring is fairly stout. You could take a look at it to see if it's stretched or mangled or something. Have you tried lowering the idle rpms using the big Idle adjusting thumb screw?
Last edit: 20 May 2014 05:57 by martin_csr.
20 May 2014 04:16
To determine whether there's a cable issue, could disconnect the cable at the carb, and see if the problem persists without the throttle cable attached. Is it then still necessary to manually push the carbs fully closed?
If not, could add some slack in the cable, assure the cable is in good condition, adequately lubed, free of kinks, and routed correctly with smooth curves.
If so, could inspect, clean and lube the carb throttle assembly mechanism.
- Willl33
26 Mar 2022 15:39
New air screw O rings and screws set to 2 and 3/4 out finally fixed mine. Best £4 I ever spent.
- azman857
26 Mar 2022 19:03
Replying to an 8 y.o. thread ?
- Willl33
28 Mar 2022 10:38
Well yes really, having tried everything suggested in all posts 8 years or not re hanging, the cure was one that hasn't been mentioned.
- Irish Yobbo
28 Mar 2022 15:57
I'm always happy when someone replies with the solution to their problem - even after 8 years.
1981 KZ750 LTD
The following user(s) said Thank You: badgb21
