Idle adjustment isn't going good.
- lindseyss
10 May 2014 15:40
I tried to adjust the idle up and it did not go up then turned it the other way and it kept dying. Then turned the knob clockwise and it did come back up and will idle. But now when i crack the throtle it takes about 5 seconds for it to come back down to idle. Any suggestions?
- Topper
Re: Idle adjustment isn't going good.
10 May 2014 16:24
I think a hanging idle can be caused by leaky carb boots.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
The following user(s) said Thank You: lindseyss
- nickleo373
10 May 2014 17:23
Sounds like a vacuum leak. Spray some carb cleaner around your intake boots and listen for a change in idle. If the idle changes you have to replace the boots
1981 KZ550C LTD
"If you ain't first, you're last"
