Fuel air mixture screw factory setting..
- hotdogg
- 1982 kz750 spectre
Re: Fuel air mixture screw factory setting..
27 May 2014 11:38
Mine came with the plug. What would happen if I removed to plug?
1982 kz750 spectre
- n9viw
27 May 2014 16:54hotdogg wrote: Mine came with the plug. What would happen if I removed to plug?
There's a small passageway that connects the main port to the pilot port. If the plug isn't there, it's not going to draw correctly, and depending on the level of your float, you'll likely run very lean. Cycle Recycle has the plugs: www.newmotorcycleparts.com/fuel_system_p...misc_carb_parts.html , look about halfway down the page for "fuel passage plug".
Nick
1982 KZ750M1 (CSR750), aka "Bat Outta Hell"
The following user(s) said Thank You: hotdogg
- Mr Underhill
18 Nov 2018 15:53
I have an 83 KZ750 N2 Spectre.
I just drilled out those "Pilot Screw" caps, I needed to do a complete cleaning and rebuild, when I removed the "Pilot Screw" I checked each one and they all went in 2 & 1/4 turns.
These are the before and after pictures from removing the "Welsh plugs" and the "Pilot Screw".
I also added a picture with everything removed...
I hope that helps you.
Cheers!!!
Nothing is impossible, sometimes it just takes a little longer.
Cheers!!!
