Where to buy jet needles?
- ShouterVW
07 May 2014 21:12
Okay, so I found my stock 5cl30 jet needles again, and all but 1 are in good shape, one has a slight bend to it. Where am I able to buy needles? If not a 5cl30, is there a suitable replacement? Thanks
- nickleo373
Re: Where to buy jet needles?
07 May 2014 21:19
Try jetsrus.com. They have a lot of carb parts over there
1981 KZ550C LTD
"If you ain't first, you're last"
- 4TheKZ1000
- gd4now
- Denco where did you go?
08 May 2014 09:16
Depending upon just how bent and the location of the bend on the needle you may be able to "fix" it. Place it between 2 small blocks of wood and roll them back and forth.
As to locations to purchase carb parts check out these. Please keep in mind that I have not visited each of these sites recently so do not know if they have what you are seeking or not. I do know that not all of the needles used in the past are currently available. You might have to purchase 4 that are similar in length, diameter and taper(s).
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.oldbikebarn.com/Motorcycle_Parts/Carb-Rebuild-Kit
www.cycleorings.com/
www.z1enterprises.com/
www.sudco.com
www.nrp-carbs.com
www.carbparts.com
www.jetsrus.com
www.sudco.com
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- ShouterVW
08 May 2014 10:37
It is only barely bent at the tip. I was unaware that they could straightened to usable shape. Thanks!
