Air Box Mods
  • diego092409
  • diego092409's Avatar Topic Author
Air Box Mods
07 May 2014 05:13 - 07 May 2014 05:15
#631642
I have too much time at work to think about these things and not enough time at home right now to actually do the work..
I am preparing for putting a monoshock mount, as part of a swapping in a new swing arm, on my 1982 GPZ1100 and the new shock and mount will be displacing the battery which is located below the 3 section airbox. To gain real estate for the battery, I am contemplating removing the air filter element section and the intermediate section and putting in an appropriately sized 22 degree bend to connect the stilling box to a rectangular K&N type Universal Air Filter.
I am not looking specifically for performance gains as much as I am looking for space to put a small battery between back of the air filter and the subframe where the existing filter is. Unless I want to change over to a microsquirt so that I can scrap the existing ECU, I don't have any real estate in the tail section. I do plan to put in an Eastern Beaver PC-8 Fuse box to replace the existing main fuse box and I plan to not discard the air temp sensor that is mounted in the middle section. I like the look of he existing airbox at this time, so, for that reason, I am not looking to discard it and put in pods. I just want to know if you all think this will work or not.
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
Last edit: 07 May 2014 05:15 by diego092409.
