650 to 550 carb swap
  • piratedog
  • piratedog's Avatar Topic Author
06 May 2014 23:15 - 06 May 2014 23:16
#631627
hey guys new to forum.. first post...i have an '82 kz550 with slide carbs, i was wondering if anyone could tell me if the carbs off the 650 would swap over? if not what carbs will swap out???(cant find a stock set any where in my area).
any help would be appreciated!!!
Last edit: 06 May 2014 23:16 by piratedog.
  • floivanus
  • floivanus's Avatar
Re: 650 to 550 carb swap
06 May 2014 23:36
#631628
Cylinder spacing is different between the 550 and the 650, so short answer, not gonna swap over
Past; 78 kz1000, 83 kz550
Andrew
  • martin_csr
  • martin_csr's Avatar
07 May 2014 05:53
#631643
There are a number of carburetor sets listed on eebbaayy & most of them are over $100.
Is there something wrong w your current set?
The following user(s) said Thank You: piratedog
  • piratedog
08 May 2014 00:58
#631772
my originals have 2 of the arms broken that operate the slides....thanks
  • martin_csr
08 May 2014 05:08
#631791
There's a cheap set from an 81 550C listed right now on eebbaayy. The seller says the slides are frozen, but some penetrating oil may solve that so that you could use them for parts or something. I guess the 81 carbs are about the same as yours (?).
