Not getting fuel. Stock 1982 GPz750
  • freakinbike
  • freakinbike's Avatar Topic Author
05 May 2014 21:01
#631475
Title says it all. I filled my tank to test my float heights and when I went to check, nothing poured out of the float bowls. The petcock was on PRI. I've been having issues with gunk in the tank, so I cleaned out the petcock and tried again. Nothing.
With the tank off, however, and setting the fuel tap to PRI, fuel flows freely. But as soon as I attach the tank to the carbs, fuel doesn't flow. I tried holding the tank high so that the fuel line was basically straight down (not kinked) and nothing flowed through.
I was getting fuel fine last time I test rode it, so I don't understand what could be happening now.
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
  • Nessism
  • Nessism's Avatar
  • Away
Re: Not getting fuel. Stock 1982 GPz750
06 May 2014 05:55 - 06 May 2014 05:56
#631487
Either the line is kinked, you have a plugged fuel filter, or the float needles aren't letting fuel into the carbs.
Did you check for fuel in the carbs by removing the float bowl drain screws?
Last edit: 06 May 2014 05:56 by Nessism.
  • baldy110
  • baldy110's Avatar
06 May 2014 09:34
#631522
Check the tank vent in the cap.
  • freakinbike
06 May 2014 20:33
#631608
Nessism wrote: Either the line is kinked, you have a plugged fuel filter, or the float needles aren't letting fuel into the carbs.
Yes, I checked for fuel in the carbs by removing the float bowl drain screws. There was hardly anything.
How would I adjust the float needles to let fuel into the carbs?
1973 VW Bus
  • nickleo373
  • nickleo373's Avatar
06 May 2014 21:08
#631616
You would need to take the carbs off to get to the float needle. The needle is located inside the seat underneath the float. Sometimes dirt gets inside the needle and seat and cruds them both up blocking fuel from entering the carb. Another problem you can have is your float levels being set too high so the tang on your floats keeps the needle stuck in the closed position
1981 KZ550C LTD
"If you ain't first, you're last"
