29 mm smoothbores
  • Zapzuta
  • Zapzuta's Avatar Topic Author
29 mm smoothbores
05 May 2014 17:44
#631455
What is the slide setting for 29mm smoothbores? (Opening in the bore bottom of the slide)
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 29 mm smoothbores
05 May 2014 18:03 - 05 May 2014 18:15
#631459
On the throttle valve cutaway / slide, I ran 1.5
www.sudco.com/Diagrams323728/expvm29.gif
29 smoothbores on a mildly modified street machine.
120 to 125 main jet
# 20 Pilot Jets
# 0-4 or 0-6 Needle Jet
# 0.9 to 1.0 Air Jets
# 2.5 Needle & Set
* Float level heights, base of gasket to top of float 23.5 - 24.5mm
Last edit: 05 May 2014 18:15 by 4TheKZ1000.
  • Zapzuta
05 May 2014 18:12 - 05 May 2014 18:22
#631461
The measurement of this gap
Last edit: 05 May 2014 18:22 by Zapzuta.
  • Haybus
  • Haybus's Avatar
  • Big Al
05 May 2014 19:25
#631466
Mikuni manual says 0.020"-0.030". The actual opening when idling is set by the throttle stop so more important they're all set the same.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • Zapzuta
05 May 2014 19:52
#631469
Thanks guys!
