750 CV34 Jetting with pods and stock exhaust
- MagnusMax
04 May 2014 10:37
Hey guys, newb here. I've searched around but haven't seemed to find a thread with a combination exactly like mine: I've got a stock Kawasaki 4 into 2 exhaust, but pod filters, which were put on by the previous owner. Bike is an '83 Kz750 Spectre. He complained that the bike didn't run well, which is no surprise I guess since the carbs were not rejetted to compensate for the extra airflow of the pods.
I know that it would probably run better with the stock airbox, but all my airbox ducts, filter mounting stuff, etc. is missing, so it's a lot cheaper to buy some carb jets than it is to try to restore the factory setup.
Anyway, for this combination what jets should I try? Carbs are the older(?) version, with two main jets, 90 and 65. The jet needle is an N10A -not N01A as I have read on some threads, and not N100 as I have seen on other threads, but N10A.
Thanks!
Thanks!
1983 KZ750 Spectre
- MagnusMax
Re: 750 CV34 Jetting with pods and stock exhaust
05 May 2014 17:16
Alright, having done some research, it seems like the Spectres and maybe other shaft bikes had this particular stock jetting. As much as I would love to advance the art and science of kz carb lore by figuring out what works, I think realistically it's not a great idea in my case since I would actually like the thing to be rideable sometime in the next year, hehe. The accepted #70/#140 jetting probably won't work because I have no idea what kind of differences there are between the needles, and I don't think N01A jet needles are obtainable unless I want to buy a whole new rack of carbs.
So, I'm going to thoroughly clean the carbs as originally planned, but I will leave the jetting as stock, and then I think I'm going to start accumulating parts to return the factory airbox to service.
In the meantime, however, since I have pods on the bike now, I'll probably try the elastic wrist sweatbands jerry-rig to reduce the amount of air they flow, and see if that will get me by.
1983 KZ750 Spectre
05 May 2014 17:22
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a start on the airbox search. Ed
