Keihin Carbs 82 750ltd
- Witchwerx
03 May 2014 11:23 - 03 May 2014 11:53
I tried in vain searching and I apologize I'm not the best on the computer. If I need to get new floats, the pins the hold the floats, needles, floats bowl screws, etc. where do I go? Kawasaki Parts only went to 84 and I'm dealing with an 82 Keihin for a 750 ltd and not terribly knowledgeable on parts sources for Kaws, I looked at the CSR versions on Bike Bandit for at least some part numbers but theyre all on back order. I appreciate the help everyone. I'd like to stay OEM if possible, too many bad times with aftermarket. Thanks again everyone.
Last edit: 03 May 2014 11:53 by Witchwerx. Reason: added bikebandit search
- NHenneous
The following user(s) said Thank You: Witchwerx
- Witchwerx
Re: Keihin Carbs 82 750ltd
03 May 2014 11:59
z1 had the screws which were expensive but available, thanks for the lead to that site. The pins for the floats and floats themselves still evade me.
- undiablo
03 May 2014 17:27
Foat bowls screws are fairly common metric #4 x 15mm long if I remember OK.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
03 May 2014 18:50 - 03 May 2014 18:55Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- Witchwerx
03 May 2014 20:53
Wow, internet high five to all of you. This gets me exactly where I need to be. I'll post it when it's rideable.
Thanks again.
