'77 kz1000 Carb sync. Cylinder #2 unsyncable.
30 Apr 2014 21:56 #630988 by Rage
I recently rebuilt the and cleaned the carbs on my '77 kz1000 A1. Installed pods. Still has factory 4 into 2 exhaust. Upped the mains from 105 to 107.5. Pilot jets are the 15.
Runs fine. Went to sync carbs. Readings
Cylinder#1- 23 cmHg
Cylinder#2-21 cmHg
Cylinder#3-10 cmHg
Cylinder#4-21 cmHg
Factory manual says to set vacuum between 20-28 cmHg. But there isn't enough screw to adjust the one carb. You guys think its a vacuum leak or valve lash on the one cylinder or what??
'77 kz1000
'78 kz1000
'81 kz750
30 Apr 2014 23:37 #630995 by 74ullc
Did you bench synch the carbs? That's when you get all the slides even in height with each other.
Is it #2 or #3 that wont synch up? From your numbers its #3 that has the slide too high compared to the others. Also according to my service manual the 1977 LTD (B1) has 105 mains and 15 pilots, the 1977 A1 has 107.5 mains and 17.5 pilots. With pods you will probably need more like 125-130 mains and 20+ pilots....from what I have read.....I'm on original airbox setup.
If the carbs wont bench synch look for bent/broken linkage or other mechanical problem. When I got my bike #1 would not bench synch with the other three (it was too high and out of adjustment).....turned out the little linkage plate inside the slide was bent, in effect shortening it causing the slide to be higher than it should have been.
Maybe you have something simple like that going on.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
01 May 2014 05:52 - 01 May 2014 05:55 #631013 by 650ed
I would check for vacuum leak on the carb holders. Here's how:
www.kzrider.com/forum/3-carburetor/59338...sync-78-kz750#628442
Also, it's possible a previous owner swapped your carbs with those from a later model. If so, the #2 carb may have a vacuum port (that was used for a vacuum operated petcock) on it that is open. If it has the vacuum port it should be located near the same position as the one on e VM24SS carbs (even though they are different than your carbs) shown below. Ed
Attachment 00005_2014-05-01.jpg not found
Last edit: 01 May 2014 05:55 by 650ed.
01 May 2014 07:52 #631026 by GregZ
Your first mistake was installing pods. Toss them in the trash re install stock airbox.
Then
Let the good times roll
just my two cents
The following user(s) said Thank You: PLUMMEN
01 May 2014 11:13 #631044 by baldy110
Replied by baldy110 on topic '77 kz1000 Carb sync. Cylinder #2 unsyncable.
Installing pods will not effect synching the carbs. It looks like you do have a vacume leak on #3. Ignore the amount of vacume just get them all the same.
01 May 2014 12:49 - 01 May 2014 19:26 #631054 by 74ullc
Don't you guys think he should pull them back off and bench sync them first? Yes, if bike still has original carb boots he has air leaks, no question. But a bench sync will get the bike running well enough to start working on chasing other problems.
Or he says its running fine....maybe start chasing other problems now and come back to sync later. The service manual gives a whole list of items to check before performing running vacuum sync. Everything from checking engine oil, spark plugs, ignition system, throttle cables, air filter, air ducts and carb linkage, compression, valve clearance, cam chain.....everything! The way I read it, vacuum sync is for when you absolutely know everything else is spot on.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
Last edit: 01 May 2014 19:26 by 74ullc.
01 May 2014 16:24 - 01 May 2014 16:25 #631064 by zukdave
Replied by zukdave on topic '77 kz1000 Carb sync. Cylinder #2 unsyncable.
When you bench sync the VM carb's remember the number two carb is the lead carb.
Set that carb first then set the rest to match.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 01 May 2014 16:25 by zukdave.
01 May 2014 19:25 #631085 by ezrider714
Replied by ezrider714 on topic '77 kz1000 Carb sync. Cylindand er #2 unsyncable.
Getting them all the same when 1 is at 10 and the other 3 in the 20's will likely be impossible :dry:
Find and fix the leak on #3 then set all 4 as close to the same and in the range specified as you can :)
If you can't find a leak then move on to checking for mechanical issues..... Linkage or such ... then might have to check valve clearance, I would put that at the bottom of the list though...
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
04 May 2014 18:56 #631335 by Twilightoptics
Replied by Twilightoptics on topic '77 kz1000 Carb sync. Cylindand er #2 unsyncable.
Definitely vacuum leak, valve adjustment, or junk in the carb.
I noticed on my VM for my 650, when I screw the 8mm head bolt down, which holds the slide mechanism to the throttle shaft, there was some play allowance when being bolted down. I found this when bench synching. One carb wouldn't close as much as the others. Loosened that bolt, rotated the slide mechanism, and retightened.
Also, pull the filters and take a look inside, does the #3 look off compared to the others? Is the pilot jet circuit clean?
There's really no need to bench synch if the bike runs, you're going to adjust them all anyways when you put your synchronizer gauges on.
1977 KZ650-B1
05 May 2014 15:57 #631438 by zukdave
Twilightoptics wrote: There's really no need to bench synch if the bike runs, you're going to adjust them all anyways when you put your synchronizer gauges on.
First the VM carb's use a tapered screw on the slide hanger
that go's in a tapered hole in the shaft there is no play when tite.
Second don't give false info. If you think there's no need to bench sync.
a set of carb's you need to learn a little more about multi carb. set up's.
Bench sync is a nechanical adjustment to set the slide's at their base setting.
Vac sync is a mean's to balance the idle air or fuel for the highest vac.
If the slide's are NOT set the same you CAN NOT balance the carb's..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
06 May 2014 07:46 #631502 by Twilightoptics
Dave, I was merely giving the information that I have.
1.) The screw is shouldered, not tapered, but there is still play. It's not a near press fit. Therefore there is further adjustment or compensation that could be had if needed or like I described above.
2.) According to my FSM... vacuum synching the carbs involves adjusting the slide height screws/jam nuts. Which, IS a mechanical adjustment. If you're adjusting those to get your highest vacuum, and the bike is already assembled and in running condition... you're going to pull the carbs off to bench synch every time first? I don't think so. In addition, there is a range for vacuum and if within range, to adjust the 3 to the highest of the 4th.
1977 KZ650-B1
06 May 2014 08:08 #631505 by 650ed
The Kawasaki Service Manual does make a clear distinction between "Initial Synchronization - Mechanical" and "Fine Synchronization - Vacuum." The mechanical sync is purely a static measurement and adjustment using a wire as a gauge, but the vacuum sync is done with the engine running so it can compensate for any variances between the individual cylinders. So even though turning a screw may in general be considered a mechanical adjustment the synchronization of the carbs using vacuum gauges is not considered to be a mechanical synchronization. The manual may have done better to refer to the two adjustments as Static and Dynamic. Ed
